Back to Blogs
5 best e-ink display manufacturers for developers and makers (2026 Guide)
26.05.2026
5 top e-ink display manufacturersReal use cases for e-ink displaysWhy Soldered might be the best e-ink paper electronic display for youE-paper displays: FAQs
E-ink paper display tablets have quietly become one of the most practical display technologies for modern hardware projects. From low-power IoT dashboards to smart labels and always-on interfaces, they offer something traditional screens can’t: visibility without constant power consumption.
But once you decide to build with an e-ink display, the next question is usually the harder one, which manufacturer should you actually choose?
Some focus on raw display modules that give you full control over your setup. Others provide more integrated solutions that help you get something working faster. The difference isn’t just in specs, it’s in how you build, how long setup takes, and how much effort goes into getting to a working result.
In this guide, we’ll break down some of the best e-ink display manufacturers used by makers and developers today, including Soldered, Waveshare, Adafruit, Seeed Studio, and DFRobot.
Instead of just listing features, we’ll look at how each one performs with real projects, so you can choose the right fit for your next project.
Choosing the right e ink display manufacturer isn’t just about specs, it’s about how you build, how quickly you can get something working, and how much effort goes into the setup.
Here’s a detailed breakdown of the most widely used e-ink display manufacturers and how they compare in real-world projects.
1. Soldered (Best for integrated e-paper display solutions)
Soldered stands out by focusing on complete, integrated solutions rather than just display modules. Their Inkplate series combines an ESP32 microcontroller with an e-ink display into a single board, which removes a large portion of the setup typically required with other manufacturers.
This approach makes a noticeable difference in practice. Instead of figuring out how to connect a display to a controller and manage power separately, you can start building immediately. For many developers and makers, this translates into faster prototyping and fewer points of failure.
Another key advantage is Soldered’s open-source philosophy. Both hardware and software are openly available, and the documentation is built around real-world projects rather than just technical references. This makes it easier to move from idea to execution without getting stuck in setup complexity.
What stands out:
  • integrated ESP32 + e-ink display (Inkplate series)
  • fully open-source hardware and software
  • Arduino-ready with minimal configuration
  • practical, project-based documentation
  • optimized for low-power, always-on use cases
Best for:
  • dashboards and always-on displays
  • IoT devices and connected systems
  • battery-powered and low-maintenance builds
€189,95 Price on 10.09.2026: 189,95 €
€189,95 - €219,95 Price on 10.09.2026: 189,95 – 219,95 €
2. Waveshare (Best for variety and flexibility)
Waveshare is one of the most widely recognized names when it comes to e ink displays, mainly because of its extensive catalog. They offer a large variety of display sizes, resolutions, and types, making them a go-to option if you need something very specific.
Their displays are compatible with platforms like Raspberry Pi and Arduino, but they are typically sold as standalone modules. This means you’ll need to handle the integration yourself, choosing a controller, managing wiring, and ensuring everything works together.
This flexibility is powerful, but it also increases setup time. Waveshare is often preferred by users who want full control over their hardware stack and don’t mind the additional complexity.
What stands out:
  • wide range of e ink display options
  • strong compatibility with multiple platforms
  • affordable and widely available hardware
  • suitable for custom and specialized builds
Tradeoff:
  • requires external controller and manual integration
3. Adafruit (Best for learning and ecosystem)
Adafruit has built a strong reputation around its ecosystem and educational content. While they offer e ink display modules, their real strength lies in how well everything is documented and supported.
Their guides are detailed, beginner-friendly, and often explain both how and why something works. Combined with their CircuitPython ecosystem, this makes Adafruit an excellent choice for those who are learning or exploring new hardware concepts.
That said, their approach is still modular. You’ll typically combine a display with a microcontroller and other components, which means more setup compared to integrated solutions.
What stands out:
  • high-quality tutorials and documentation
  • strong CircuitPython and Arduino ecosystems
  • reliable hardware and consistent quality
  • active community support
Tradeoff:
  • modular approach requires more setup and integration
4. Seeed Studio (Best for modular IoT systems)
Seeed Studio positions itself as a broader hardware ecosystem, especially with its Grove system. This plug-and-play approach simplifies connecting sensors and modules, making it easier to scale projects without complex wiring.
Their e ink display offerings fit into this larger ecosystem, which makes them particularly useful for IoT and environmental monitoring systems. If your project involves multiple sensors or needs to scale over time, Seeed Studio provides the tools to do that.
However, the ecosystem itself can introduce complexity. Understanding how different modules interact and how to structure your system takes more planning compared to more integrated solutions.
What stands out:
  • Grove plug-and-play ecosystem
  • strong focus on IoT and industrial applications
  • wide compatibility with sensors and modules
  • scalable for larger systems
Tradeoff:
  • ecosystem complexity and setup planning
5. DFRobot (Best for education and simple builds)
DFRobot focuses on accessibility and ease of use. Their hardware is designed to be approachable, making it a popular choice for education, beginners, and simple prototypes.
Their e ink display options are straightforward and functional, but not as specialized or advanced as some other manufacturers. The main advantage is how quickly you can get started without needing deep technical knowledge.
For more advanced or highly customized projects, users often outgrow this ecosystem, but it remains a solid starting point.
What stands out:
  • beginner-friendly hardware and modules
  • affordable and easy to access
  • simple setup for basic projects
  • good entry point for learning
E ink displays are used across a wide range of projects, mainly because of their unique combination of low power consumption and excellent readability. Unlike traditional screens, they don’t require constant power to maintain an image, which makes them ideal for devices that need to run continuously or update only occasionally.
Here are some of the most common real-world applications:
Dashboards (home and office)
E ink displays are a popular choice for dashboards that show information like weather, calendars, task lists, or system status. Since the screen remains visible without refreshing, it works well for “glanceable” information that you want to check throughout the day without distractions.
Inkplate 6FLICK
Inkplate 6FLICK
€209,95 Price on 10.09.2026: 209,95 €
€179,95 - €209,95 Price on 10.09.2026: 179,95 – 209,95 €
IoT devices
In IoT projects, power efficiency is often critical. E ink displays fit perfectly into these setups because they consume very little energy, especially when the content updates only periodically. They are commonly used for device status displays, sensor readouts, and remote monitoring systems.
Digital signage
For static or semi-static content, such as menus, schedules, or information boards, e ink displays offer a clean and paper-like look. They are particularly useful in environments where power availability is limited or where screens need to run continuously without frequent maintenance.
Smart labels
E ink is widely used in electronic shelf labels and inventory systems. These displays can update prices or product information remotely while consuming almost no power between updates, making them highly efficient for retail and logistics applications.
While each e-ink display manufacturer brings something valuable to the table, the right choice ultimately comes down to how you prefer to build.
If you’re comfortable assembling systems from multiple components and want maximum flexibility, options like Waveshare, Adafruit, and Seeed Studio can take you far. But if your goal is to reduce setup time and get to a working result faster, more integrated solutions start to stand out.
This is where Soldered offers a clear advantage, especially for makers and developers who value simplicity, reliability, and speed.
What makes Soldered a strong choice:
  • integrated ESP32 + e ink display (Inkplate series)
  • Arduino-ready with minimal setup
  • documentation built around real projects, not just specs
  • optimized for low-power and always-on use cases
  • faster path from idea to working prototype
In practice, that means less time troubleshooting and more time building something that actually works.
What is an e-ink display and how does it work?
An e ink display uses tiny charged particles to create an image, which means it only consumes power when the content changes. Once something is displayed, it stays visible without using additional energy, making it very different from traditional screens like LCD or OLED.
What is the difference between e-ink and e-paper displays?
In most cases, there’s no real difference, the terms are used interchangeably. “E ink” refers to the underlying technology, while “e paper display” is a more general term used to describe screens that mimic the look and behavior of paper.
Which e-ink display manufacturer is best for beginners?
It depends on what kind of experience you’re looking for. Adafruit is often a great starting point because of its detailed tutorials and educational content. However, if you want to get something working quickly without spending too much time on setup, integrated solutions like Soldered can feel more straightforward.
Which e-ink displays work best with Arduino?
Many manufacturers support Arduino, including Soldered, Waveshare, Adafruit, and Seeed Studio. In practice, Soldered tends to be easier to work with because the hardware and libraries are designed to work together out of the box, while other options may require more manual integration.
Are e-ink displays good for IoT projects?
Yes, they’re one of the best options for IoT projects, especially when power efficiency is important. Because they don’t need constant refreshing, they’re ideal for devices that display information like sensor data, status updates, or dashboards over long periods.
What is the main challenge when working with e-ink displays?
The biggest challenge is usually integration. Many e ink displays are sold as standalone modules, which means you need to connect them to a microcontroller, manage power, and configure libraries. This is where more integrated solutions can save a lot of time.
Do I need a microcontroller to use an e-ink display?
In most cases, yes. Displays from manufacturers like Waveshare or Adafruit typically require a separate microcontroller such as an Arduino or ESP32. Some solutions, like Soldered’s Inkplate, already include a microcontroller on the board, which simplifies the setup significantly.
Which e-ink display is best for low-power or battery projects?
E ink displays are naturally suited for low-power applications, but the overall efficiency depends on the setup. Integrated boards designed specifically for low-power use can make a noticeable difference, especially in projects that need to run for weeks or months on a single charge.
