14.07.2026
Best e ink displays for Arduino projects (2026 guide)
If you are building a smart desk calendar, an outdoor weather station, or anything that needs to run on a battery, a standard LCD or OLED screen is not always the right choice. They draw too much power, and they are hard to read in direct sunlight. This is where a low-power display solution named e ink comes in.
E ink display screens are bistable, which means they only draw power while the image is changing. If there is a sudden power outage or your battery disconnects, the last rendered image stays on the screen indefinitely, until the next system update.
E-paper technology works quite differently from a standard emissive display. It is not made for fast image refreshes or smooth animations. Its refresh rate is slow, and you will notice a visible “flashing” effect when the device clears the screen canvas. In this guide, we will go through how to choose the best e ink display for your next Arduino project, what you need to know about voltage compatibility, and how to choose the right screen size without running out of onboard RAM.
What is an e ink display and why use it with Arduino
Instead of using a glowing backlight like your smartphone, an e-paper display Arduino project mimics real ink on physical paper. Inside the screen layer are millions of tiny microcapsules filled with charged black and white particles. By applying a brief, controlled electrical pulse, you change the polarity of these capsules and move the matching pigments to the surface, forming crisp text or sharp images.
Once those particles move into place, they stay there. An e ink display draws near-zero power, less than 1 mW while refreshing, and absolutely zero power to hold a static image on the screen. Even if your battery dies completely or you unplug the Arduino board entirely, the last image remains perfectly visible, acting as an always-on display. Pairing a screen like this with a standard 1200 mAh battery and a power-optimized microcontroller allows your project to easily run for months on a single charge without any outdoor screen glare.
What to look for in an e ink display for Arduino
When you buy a bare e ink display panel from a standard component supplier, it will not just work out of the box. The first thing to solve is the communication interface. Almost every Arduino e ink screen on the market relies on SPI (Serial Peripheral Interface), which means you will need to dedicate four to five digital pins on your board just for data transmission.
Hardware compatibility gets even trickier with voltage. Raw e ink panels typically run on 3.3V. If you connect one directly to a classic 5V Arduino board like the Uno, you will fry the screen. To keep things safe, you have to wire an external logic level shifter between the board and your display.
Logic Level Converter Board
€2,50
€2,50
Even if you get the wiring right, you still have to deal with the RAM bottleneck. Buffering crisp graphics takes a surprising amount of processing memory. A standard Arduino Uno only has 2 KB of RAM, which simply is not enough to handle a larger display frame buffer. If you want a bigger screen for your build, you need to move to a much stronger microcontroller like an ESP32.
Finally, check if the screen supports partial refresh. Without it, the whole screen has to flash black and white every time a single digit changes. If the manufacturer does not provide partial refresh drivers, you are stuck writing complex rendering code from scratch.
Managing level shifters, SPI wiring, and strict RAM limits can slow your project down a lot. If you want to skip that troubleshooting, choosing an integrated board from our Inkplate family gives you a fully documented, plug-and-play experience right out of the box.
Inkplate 10 (Best overall / easiest setup)
This is where things get easier. Inkplate 10 offers everything we just mentioned and handles it internally. You are not buying a bare display panel that needs careful and slow integration. You are buying a finished, integration-ready board built around a 9.7-inch e ink display, with all components already talking to each other.
€189,95
€189,95 - €219,95
The integrated ESP32 WROVER-E microcontroller does the heavy lifting. There is no voltage mismatch, because the microcontroller runs on 3.3V. It has 8 MB of PSRAM (Pseudo-SRAM), which is plenty of memory for buffering large grayscale images on the 1200 × 825 pixel screen. While a full display refresh takes just 1.61 seconds, the software library handles partial updates automatically. This means you can instantly change specific numbers or text without forcing a full-screen flicker every time data updates.
Most importantly, the built-in Wi-Fi and Bluetooth open up possibilities you cannot easily implement in a classic Arduino. Your display can fetch live weather data, sync with a cloud database, or pair with your phone. You are not limited to local sensor reads anymore.
It uses 22 µA in deep sleep mode. Pair it with the optional 3000 mAh Li-ion battery, and you are looking at months of real-world runtime for a display that updates every few hours.
To help you get started quickly, the documentation comes with complete examples for grayscale rendering, partial updates, image conversion, and text handling. This makes learning the board and troubleshooting your code straightforward.
Inkplate 13Spectra (Best color e ink option)
If you are looking for a bit of color, Inkplate 13Spectra has you covered. Instead of using washed-out color filters like other screens, it uses advanced multi-pigment technology. The powerful onboard ESP32 microcontroller physically manipulates black, white, red, and yellow pigments inside the microcapsules, giving you deep, vibrant color saturation that makes text and icons stand out clearly from across a room.
Inkplate 13SPECTRA
Inkplate 13SPECTRA
€279,95
ESP32 Color e-Paper Board
€279,95 - €319,95
That physical color manipulation also comes with trade-offs you should keep in mind before building your next project. Because those colored particles are heavier and more complex to move than standard black-and-white ones, partial refresh is not possible on this panel, and a full display refresh takes about 19 seconds. If your project needs instant, split-second updates, you are better off sticking to the Inkplate 10. But if you are building an information dashboard, a menu, or a smart calendar that only needs to update once every few minutes, the visual clarity and color contrast of the Spectra make it the best tool for the job.
Waveshare e ink displays (Best for flexibility)
If your project needs a very specific form factor, Waveshare offers a range of bare e-paper components, from 1.54 inch panels all the way up to large flexible screens. Buying a raw e paper panel gives you the full integration adventure if you enjoy the engineering challenge of building your hardware footprint completely from scratch.
The main trade-off is that Waveshare modules do not come with an integrated controller to control themselves. You will need to provide your own Arduino or ESP32 solution. It takes more development time and troubleshooting to get up and running, but if you need ultimate modular flexibility for a custom enclosure, they get the job done.
Adafruit e ink modules (Best for learning)
If your main goal is to learn the basics of how e-paper works, Adafruit is a good starting point. The biggest reason to consider them is their large documentation ecosystem. They do not just sell you a component and leave you to figure it out. They provide step-by-step wiring guides combined with their software libraries, so printing your first custom font or drawing basic geometric shapes on the screen is straightforward.
If you value detailed tutorials, clean software libraries, and an easy learning curve, they are a solid choice for your first prototype.
E Ink vs. OLED vs LCD for Arduino
Choosing the right screen for your Arduino project comes down to understanding what your project actually needs to do and which trade-offs you can accept.
The main reason to choose an e ink panel is if your project needs a lower power display using Arduino. Because e-paper is bistable, it drains power only when pigment needs to move. If you are making a weather display project that updates every 10 minutes, your screen spends 99% of its life drawing zero current. OLEDs, on the other hand, illuminate every individual pixel using emissive diodes. They offer rich blacks and smooth, fast refresh rates, making them a good fit for real-time sensor readouts, fast-moving UI menus, or small animations, but they will drain a small lithium battery within days if left constantly running. Traditional character or graphical LCDs need a constant, bright backlight to be readable indoors, making them the most power-hungry option of the three, though they remain cheap and easy to code.
To help you choose the right tool for your specific build, here is a quick look at how these three screen types compare:
Feature E-paper LCD OLED
Power Consumption Near Zero (only on refresh) Medium (depends on pixel count) High (due to constant backlight)
Refresh Speed Slow (1.61s - 19s for full clear) Instantly Fast (fluid animations) Fast
Sunlight Visibility Perfect (reads like real paper) Poor (completely washed out) Average (depends on glare)
Best Arduino Projects Weather stations, calendars, IoT Live sensor readouts, quick menus Lab equipment, desktop appliances
If your Arduino is plugged directly into a wall outlet or a desktop USB port and needs to show live, split-second variable changes, go with an OLED or LCD. But if your project needs to live outside on a battery pack, or sit on your desk showing an elegant, non-glaring smart calendar that updates occasionally, e ink is the only choice that will not leave you constantly swapping out dead batteries.
Real Arduino e ink projects
The best way to see the real potential of an e ink display Arduino project is to look at what you can actually build with it. Because e-paper behaves so differently from a standard emissive screen, it opens the door to some unique project use cases that simply would not work with traditional hardware.
One of the most popular builds is a smart home information dashboard. Instead of connecting all your sensors to a bright, glowing monitor that will keep you awake at night, you can place a large e-paper panel on your desk or wall to display your daily schedule, to-do lists, or server uptimes. If you want to see a practical example of this in action, check out our guide on how to build an Inkplate Sensor Hub to see how easily you can collect data from multiple sensors and push it to a clean e-paper layout.
If you want to take your build outside, low-power outdoor weather stations are another perfect fit. A traditional screen washes out completely under direct sunlight, but an e ink display actually gets crisper the brighter it is outside. You can program your Arduino or ESP32 to stay in deep sleep mode for 59 minutes out of the hour, wake up briefly to sample data from an anemometer or a barometric pressure sensor, update the display, and go straight back to sleep. Since the screen draws zero current to hold that static information, a tiny battery can power the whole project for months.
Beyond home use, e-paper is useful for remote IoT displays and smart labels in workshops or retail spaces. You can build dynamic component bin labels that update their pricing or inventory counts over Bluetooth, or build a central node that gives you all the environment data you need across your workshop floor.
Which e ink display should you choose?
Choosing the right screen comes down to an honest look at your workshop setup and how much time you want to spend troubleshooting hardware compatibility. Every option we covered has a clear purpose, so matching the screen to your actual development goals will save you a lot of trouble down the road.
If you are looking to learn the basics of SPI wiring maps using standard, beginner-friendly tutorials, starting with an Adafruit module is a good choice. On the other hand, if you are designing a custom enclosure with tight physical dimensions and you actually enjoy the engineering challenge of sourcing separate controllers, level shifters, and routing your own data lanes, the modular flexibility of a bare Waveshare panel will get the job done.
However, if your main goal is to go from initial idea to working project quickly, and you would rather spend time coding the project than troubleshooting hardware mismatches, an integrated board is usually the best tool for the job. If you want a large screen with plenty of RAM for processing detailed layouts, built-in Wi-Fi to pull online data, and a fast partial refresh that prevents constant full-screen flickering, the Inkplate 10 handles all those complexities internally right out of the box.
Ultimately, if you want a quick, frustration-free path from an idea to a working e-paper device sitting on your desk, keeping everything integrated on a single board makes the process straightforward.
Why Soldered has the best Inkplate on the market right now
We did not design Inkplate to be just another option on the market. We built it because we wanted a cleaner way to create e-paper projects without the usual hardware headaches. When everything is integrated onto a single PCB, the whole development process becomes much easier. You no longer have to spend your free time double-checking SPI pinouts, wiring external logic level shifters, or worrying about whether your microcontroller has enough RAM to render a clean image.
We handle the complex component communication and power management at the hardware level, so you can focus on writing your application. Backed by fully open-source code libraries and detailed documentation, it is designed so you spend less time troubleshooting basic wiring errors and more time making something cool.
FAQ
What is the best e ink display for Arduino?
It depends on your project end goal, but for most makers, an integrated out of the box solution like the Inkplate 10 is the best solution because it removes the problems that come with personally wiring and building an e ink display from scratch.
Are e ink displays good for IoT?
They are the gold standard for remote IoT setups. Because they draw near-zero power to hold a static image, they allow you to build a remote, battery-powered sensor that can easily run for a long time on a single charge.
Do I need ESP32 for e ink?
For small, low-resolution displays, a classic Arduino Uno works fine. However, for larger, high-resolution screens, your Uno will instantly run out of RAM trying to hold the image buffer. An ESP32 provides the processing power and the large memory footprint required to drive bigger panels smoothly.
Is e ink better than OLED?
It depends on the display use case. If your project needs to look like real paper, sit outside in bright sunlight, or run on tight battery power, e ink is for you. On the other hand, if your project requires smooth animations, high video frame rates, or bright indoor neon colors, you are much better off choosing an OLED.
Does temperature affect e ink in any way?
If you are building an outdoor weather station that experiences freezing winter temperatures, the liquid inside the microcapsules stiffens, which can slow down refresh times or temporarily stop the screen from updating until it warms back up.
Does frequent partial refreshing damage an e-paper screen?
Using partial refresh is great for changing individual numbers without a full-screen flash, but over time, it causes a physical phenomenon known as “ghosting,” where faint outlines of old text remain visible. To prevent this and keep the display looking crisp, our software libraries are designed to automatically trigger a clean, full-screen refresh every few cycles.
Related Articles
