Fast refresh e-paper displays are changing what's possible with e-paper technology. While traditional e-paper screens excel at displaying static information, faster refresh rates make them a practical option for dashboards, smart home controls, monitoring systems, and other projects that need more frequent updates.
In this guide, we'll explain how fast refresh e-paper displays work, how they compare to traditional e-paper screens, and where they make the biggest difference for makers and developers.
What is a fast refresh e-paper display?
A fast refresh e-paper display is a type of e-paper screen designed to update content significantly faster than traditional e-paper displays. While standard e-paper technology is known for excellent readability and low power consumption, it can sometimes take several seconds to fully refresh the screen. Fast refresh e-paper displays reduce this delay, making them better suited for interactive projects and frequently changing information.
The improvement comes from a combination of faster display controllers, optimized refresh algorithms, and partial refresh techniques that update only the parts of the screen that change. This helps reduce ghosting effects and creates a smoother user experience.
As a result, fast refresh e-paper displays open the door to applications that were previously difficult to achieve with traditional e-paper technology, including:
Home Assistant dashboards
Weather stations
Smart home control panels
Real-time monitoring displays
Interactive information screens
IoT status boards
While they still can't match the frame rates of LCD or OLED displays, fast refresh e-paper displays offer a compelling balance between responsiveness, visibility, and power efficiency, which makes them an attractive option for makers and developers building always-on devices.
Why refresh speed matters for e paper displays
One of the biggest criticisms of traditional e-paper displays has always been their responsiveness. If you've ever watched an e-paper screen perform a full refresh, you've probably noticed the brief flash and delay before new information appears.
For some projects, that's not a problem at all. An e-paper calendar, room schedule, or digital sign may only need to update a few times per day.
Things change when the display becomes part of a more dynamic system.
Imagine a home assistant dashboard showing energy consumption throughout the day. As new sensor readings arrive, you want charts, values, and status indicators to update quickly enough that the dashboard feels alive rather than static. The same applies to weather stations, smart home control panels, and IoT monitoring systems where information changes regularly.
Faster refresh rates help make these experiences more natural by:
Updating information more quickly
Reducing visible screen flashing
Making dashboards feel more responsive
Improving the usability of touchscreen interfaces
Supporting more dynamic layouts and widgets
This is also where fast refresh displays such as the Inkplate 6FLICK start to shine.
Fast refresh e-paper vs. traditional e-paper
Both technologies share the same core advantages: excellent readability, low power consumption, and a paper-like viewing experience. The difference lies in how quickly they can update information on the screen.
Traditional e-paper displays excel in applications where content changes infrequently, such as calendars, room signs, and digital labels. Fast refresh e-paper displays build on these strengths while making the technology practical for dashboards, monitoring systems, and more interactive projects.
Feature |
Traditional e-paper |
Fast refresh e-paper |
Refresh speed |
Slower full-screen updates |
Significantly faster updates |
Ghosting |
More noticeable during frequent refreshes |
Reduced ghosting effects |
Power consumption |
Extremely low |
Slightly higher, but still very efficient |
Dashboard use |
Best for static information |
Better for frequently updated dashboards |
Animations |
Limited |
Basic animations and smoother transitions possible |
Common use cases for fast refresh e-paper displays
Traditional e-paper displays are great when information changes occasionally. Fast refresh e-paper displays become interesting when things start changing more often.
You probably won't use one to watch videos or browse social media, but there are plenty of projects where faster updates make a noticeable difference.
Smart home dashboards are one of the most popular uses for fast refresh e-paper displays. Instead of displaying static information, they can update room temperatures, energy usage, weather forecasts, and device statuses throughout the day while still maintaining the low-power benefits of e-paper.
Many Home Assistant dashboards rely on ESP32-powered devices to collect and transmit data. The NULA Mini ESP32-C6 combines Wi-Fi 6, Bluetooth 5, and Matter support, making it an excellent foundation for connected dashboard projects.
Weather stations
A weather station isn't very useful if it's always showing outdated data. Fast refresh displays make it easier to keep temperature, humidity, air quality, and forecast information up to date without sacrificing visibility in bright environments.
Energy and solar monitoring
If you're tracking electricity consumption or solar production, small changes happen constantly. Faster refresh rates help dashboards feel more responsive and make it easier to spot trends as they happen.
Want to visualize power consumption on an e-paper dashboard? The INA219 Current & Voltage Sensor makes it easy to track energy usage, battery performance, and solar production in real time, creating a perfect use case for a fast refresh display.
Fast refresh e-paper displays with touch support create an interesting middle ground between traditional e-paper and LCD screens. You get an always-visible display that can still be used to trigger automations, control lights, or switch between dashboard views.
IoT projects and status boards
This is where many makers get creative. Fast refresh e-paper displays can be used for everything from greenhouse monitoring systems and workshop dashboards to office status boards and custom IoT devices that need to display changing information throughout the day.
The sweet spot for fast refresh e-paper isn't replacing LCD screens. It's enabling projects that need more frequent updates while keeping the readability and power efficiency that make e-paper so appealing in the first place.
Inkplate 6FLICK: a fast refresh e-paper display for makers
Many e-paper displays force you to choose between low power consumption and responsiveness. The Inkplate 6FLICK was designed to bridge that gap by combining fast refresh technology, touch support, and the flexibility of an ESP32-based platform.
For makers who want to build something more interactive than a traditional e-paper project, it opens up a range of possibilities that simply weren't practical with older e-paper displays.
What makes Inkplate 6FLICK different
At its core, the Inkplate 6FLICK is built around a fast refresh e-paper display that can update information much more smoothly than traditional e-paper screens. This makes it a strong fit for projects where data changes throughout the day or users need to interact with the display.
Unlike many e-paper solutions, it's designed with makers in mind, offering a development experience that's familiar to anyone who has worked with ESP32, Arduino, MicroPython, or ESPHome.
Touch support that stands out
One of the standout features of the Inkplate 6FLICK is its capacitive touchscreen. Instead of simply displaying information, the screen can become part of the user experience.
This makes it possible to:
Navigate between screens
Trigger automations
Control smart home devices
Interact with menus and dashboards
Build custom user interfaces
ESP32 integration
The built-in ESP32 provides plenty of flexibility for IoT and connected projects. Whether you're pulling data from sensors, connecting to Home Assistant, or communicating over Wi-Fi, the ESP32 ecosystem gives makers access to a huge range of libraries, tools, and integrations.
The board also works well with popular development environments such as:
Arduino IDE
ESPHome
MicroPython
PlatformIO
Home Assistant compatibility
If you're building a smart home dashboard, the Inkplate 6FLICK is particularly interesting. The combination of fast refresh technology and touch support makes it much better suited to dynamic dashboards than traditional e-paper displays.
It can be used to display:
Weather information
Room temperatures
Energy consumption
Device status
Security alerts
Smart home controls
How Soldered is helping makers build more responsive e-paper display projects
For years, makers had to make a choice. They could use traditional e-paper displays and benefit from incredible readability and low power consumption, or they could switch to LCD screens when their projects needed faster updates and more interaction.
Fast refresh e-paper is helping close that gap.
At Soldered, we've seen makers use e-paper displays for everything from Home Assistant dashboards and weather stations to energy monitors and custom IoT devices. As projects become more dynamic, the need for faster updates becomes increasingly important, which is exactly why products like the Inkplate 6FLICK exist.
The exciting part isn't the technology itself. It's what you can build with it. A dashboard that updates throughout the day. A touchscreen control panel for your smart home. A monitoring system that displays real-time information without relying on a power-hungry screen.
Fast refresh e-paper displays: FAQs
A fast refresh e-paper display is an e-paper screen designed to update content more quickly than traditional e-paper displays. This makes it better suited for dashboards, monitoring systems, interactive interfaces, and other applications where information changes regularly.
How fast can a fast refresh e-paper display update?
Refresh rates vary depending on the display technology and the type of content being updated. Fast refresh e-paper displays can update significantly faster than traditional e-paper screens, especially when using partial refresh techniques that only update portions of the display.
What is the difference between fast refresh e-paper and traditional e-paper?
The main difference is update speed. Traditional e-paper displays are optimized for static content, while fast refresh e-paper displays are designed to handle more frequent updates with reduced ghosting and smoother screen transitions.
Are fast refresh e-paper displays good for Home Assistant dashboards?
Yes. Fast refresh e-paper displays are well suited for Home Assistant dashboards because they can display changing sensor data, weather information, energy monitoring statistics, and smart home statuses more effectively than traditional e-paper screens.
Can fast refresh e-paper displays be used for touchscreens?
Some models, including displays like the Inkplate 6FLICK, combine fast refresh e-paper technology with capacitive touch support. This allows users to interact with dashboards, menus, and smart home controls directly from the display.
What are the benefits of fast refresh e-paper displays?
The biggest benefits include:
Faster screen updates
Reduced ghosting
Better support for dashboards and monitoring systems
Excellent readability in bright environments
Low power consumption compared to LCD displays
Are fast refresh e-paper displays more energy efficient than LCD screens?
Yes. While fast refresh e-paper displays typically consume slightly more power than traditional e-paper screens, they remain significantly more energy efficient than most LCD and OLED displays because they only use power when updating the screen.
