Qwiic ecosystem explained: What it is and why makers use it
30.06.2026
What is the Qwiic ecosystem?Product Highlight: Inkplate 10What is a Qwiic connector?Common Qwiic modules, sensors, and project ideasHow Soldered helps makers get more from the Qwiic ecosystemQwiic ecosystem; FAQs
If you've ever connected a sensor to a development board, there's a good chance you've spent more time looking at wiring diagrams than actually building your project. One wrong connection and suddenly you're troubleshooting instead of creating.
That's exactly the problem the Qwiic ecosystem was designed to solve. By replacing complex wiring with simple plug-and-play connectors, Qwiic makes it easier to connect sensors, displays, and other modules without soldering or guessing which pin goes where.
In this guide, we'll explore how the Qwiic ecosystem works, what makes it so popular among makers, and why systems like easyC are helping developers build projects faster than ever before.
The Qwiic ecosystem is a collection of compatible development boards, sensors, displays, and modules that use a standardized connector to communicate over I2C. Instead of manually wiring multiple pins together, makers can connect devices using a simple cable and start building almost immediately.
At its core, Qwiic was created to remove one of the biggest frustrations in electronics projects: wiring. By standardizing connections across a wide range of components, it becomes much easier to prototype, experiment, and expand projects without worrying about complex schematics or soldering.
Some of the key components of the Qwiic ecosystem include:
  • Development boards
  • Environmental sensors
  • Motion and proximity sensors
  • GPS modules
  • RTC (real-time clock) modules
  • OLED displays
  • Communication modules
The result is a more beginner-friendly approach to electronics that allows makers to focus on building projects rather than troubleshooting connections. Whether you're creating a weather station, smart home device, or IoT prototype, Qwiic helps get your hardware up and running faster.
Turn sensor data into an always-on dashboard
Once your sensors start collecting data, you'll usually want a way to display that information. That's where the Inkplate 10 comes in. Powered by ESP32 and featuring a large e-paper display, it's a popular choice for Home Assistant dashboards, weather stations, energy monitoring systems, and other projects that benefit from always-on visibility without the power consumption of a traditional LCD screen.
Why makers choose Inkplate 10:
  • Large e-paper display with excellent readability
  • ESP32-powered for Wi-Fi connectivity
  • Ideal for Home Assistant dashboards
  • Great for weather and monitoring projects
  • Low power consumption compared to traditional displays
Popular projects:
  • Home Assistant dashboard
  • Weather station
  • Energy monitoring display
  • Smart home status board
  • IoT information panel
€189,95
€189,95 - €219,95
The entire Qwiic ecosystem revolves around one small component: the Qwiic connector.
If you've ever built a project using jumper wires, you've probably experienced the usual problems. Wires come loose, connections get mixed up, and troubleshooting can quickly become more time-consuming than the project itself.
The Qwiic connector was designed to eliminate that friction.
A closer look at the connector
Unlike traditional prototyping setups that may require four separate wires for I2C communication, a Qwiic connector bundles everything into a single connection.
Here's what travels through the cable:
Pin
Purpose
VCC
Powers the connected module
GND
Ground connection
SDA
Transfers data
SCL
Synchronizes communication
For the user, this means no manual pin mapping and no wondering whether SDA should connect to pin A4 or A5.
Why makers like it
The biggest advantage isn't speed. It's confidence.
When you connect a Qwiic sensor to a compatible development board, you know the hardware is connected correctly before you even write your first line of code.
That leads to:
  • Faster prototyping
  • Cleaner project layouts
  • Fewer wiring mistakes
  • Easier debugging
  • Better beginner experience
Not all cables are created equal
Qwiic devices typically use compact JST-SH cables, which are available in multiple lengths depending on your project.
Short cables work well for compact electronics builds, while longer cables make it easier to spread components throughout larger enclosures, dashboards, and IoT projects.
It's a small detail, but it's one of the reasons the Qwiic ecosystem feels so approachable. Instead of spending time figuring out how to connect components, you can focus on what you actually want to build.
Every Qwiic-style ecosystem relies on simple, reliable connections. The easyC cable 10cm makes it easy to connect compatible sensors, displays, and modules without soldering or complicated wiring, helping you get from idea to prototype faster.
Qwiic Cable
Qwiic Cable
€0,95
€0,75 - €1,50
One of the reasons the Qwiic ecosystem has become so popular is the sheer variety of modules available. You can start with a single sensor and a development board, then gradually expand your project as new ideas come to mind.
Start with a sensor
Many makers first encounter Qwiic while building simple monitoring projects.
Popular modules include:
  • Environmental sensors for temperature, humidity, pressure, and air quality
  • Real-time clock (RTC) modules
  • Current and voltage sensors
  • GPS modules
  • OLED displays for visualizing data
The beauty of the ecosystem is that these modules all connect in the same way. Once you've connected one device, adding another feels familiar.
Then turn data into something useful
A temperature sensor by itself isn't particularly exciting. But when you combine sensors, displays, and connectivity, projects start becoming much more interesting.
A few examples:
Build a weather station
Combine an environmental sensor with a display to create a live weather dashboard for your home, workshop, or classroom.
If you're building a weather station, greenhouse monitor, or indoor air quality tracker, environmental sensors are often the first module you'll reach for. A module like Soldered's BME688 Environmental Sensor can measure temperature, humidity, pressure, and air quality, making it a popular starting point for smart home and IoT projects.
Monitor your smart home
Use sensors to track room temperature, humidity, light levels, or air quality and feed the data into Home Assistant.
Track energy usage
Current and voltage sensors can help you understand how much power your devices consume throughout the day.
Create a data logger
Pair sensors with an RTC module to record measurements over time and analyze trends later.
Build smart home devices
Every smart home project needs a brain. Development boards such as the NULA Mini ESP32-C6 pair perfectly with Qwiic-compatible sensors and displays, offering Wi-Fi 6, Bluetooth 5, and Matter support for modern connected devices.
Great for learning, even better for prototyping
Qwiic is particularly popular in educational environments because students can focus on understanding sensors and code rather than debugging wiring mistakes.
The same advantage applies to experienced makers. When you're testing a new idea, the last thing you want is to spend an hour figuring out whether a loose jumper wire is causing the problem.
Where many projects eventually lead
Interestingly, many Qwiic projects start small and grow over time.
A simple temperature sensor becomes a weather station
A weather station becomes a Home Assistant integration
A Home Assistant integration becomes a full IoT monitoring system
Because modules can be added so easily, the ecosystem naturally encourages experimentation, which is exactly what makes building projects fun in the first place.
The Qwiic ecosystem isn't really about connectors or cables. It's about removing friction from the building process. Less time spent wiring components means more time experimenting, learning, and turning ideas into working projects.
That's a philosophy we share at Soldered.
Our easyC ecosystem was built around the same idea: making electronics more approachable without limiting what makers can create. Whether you're connecting environmental sensors, displays, RTC modules, or wireless development boards, the goal is to help you get from concept to prototype as quickly as possible.
The best part is that you don't need to start with a complicated project. Connect a sensor, display the data on a screen, add a few more modules, and see where your curiosity takes you. Many of the most interesting projects start with a single cable and a simple idea.
And when you're ready to expand, the ecosystem grows with you.
The Qwiic ecosystem is a collection of compatible development boards, sensors, displays, and modules that communicate using I2C through a standardized 4-pin connector. It simplifies wiring and makes prototyping faster and easier.
A Qwiic connector is a small 4-pin JST-SH connector that carries power and I2C communication signals between compatible devices. It allows makers to connect modules without soldering or manually wiring pins.
How does the Qwiic ecosystem work?
The Qwiic ecosystem uses a standardized connector and I2C communication protocol. Simply connect a compatible module to a development board using a Qwiic cable, upload your code, and start interacting with the device.
What is the difference between Qwiic and I2C?
I2C is the communication protocol used by devices to exchange data. Qwiic is a hardware ecosystem built around I2C that standardizes connectors and cables, making it easier to connect devices without manual wiring.
What is the difference between Qwiic and easyC?
Both Qwiic and easyC are designed to simplify I2C connections. They use similar plug-and-play concepts, allowing makers to connect sensors and modules quickly. easyC is Soldered's ecosystem that focuses on compatibility, simplicity, and rapid prototyping.
Can I use Qwiic modules with Arduino?
Yes. Most Qwiic modules work with Arduino-compatible boards as long as the board supports I2C communication. Many manufacturers also provide Arduino libraries and example code to help you get started.
Can I use Qwiic sensors with ESP32?
Absolutely. ESP32 boards are commonly used with Qwiic-compatible sensors and modules. This combination is popular for IoT projects, Home Assistant integrations, environmental monitoring, and wireless sensor networks.
What can you build with the Qwiic ecosystem?
The Qwiic ecosystem can be used to build a wide range of projects, including:
  • Weather stations
  • Smart home devices
  • Home Assistant sensors
  • Data loggers
  • GPS trackers
  • Energy monitoring systems
  • IoT prototypes
  • Educational electronics projects
Are Qwiic cables universal?
Most Qwiic devices use the same 4-pin JST-SH connector standard, allowing compatible modules to work together regardless of the specific sensor or accessory being used.
Is the Qwiic ecosystem good for beginners?
Yes. One of the biggest advantages of the Qwiic ecosystem is its beginner-friendly design. By reducing wiring complexity, it allows new makers to focus on programming and project development instead of troubleshooting hardware connections.
