Introduction
If you have spent any time working with Arduino, Raspberry Pi or other maker platforms, chances are you have run into something called a breakout board. They appear in tutorials, starter kits and development boards everywhere. Even if the name sounds simple, many beginners are not quite sure what breakout boards actually are or why everyone uses them.
In this guide, we break down what breakout boards do, why they make prototyping easier and what you should watch out for before choosing one. Whether you are building your first project or refining a complex design, breakout boards can save time, reduce wiring mistakes and open up a wide range of sensors and capabilities.
[IMAGE PLACEHOLDER 1]
What breakout boards are and why they exist
Many electronic components come in the form of integrated circuits, also known as ICs. These chips can be incredibly capable, but they often come in tiny packages with very small pins that cannot be plugged into a breadboard. Some chips have dozens of pins with spacing far too small to handle by hand.
A breakout board solves this problem. It takes a single chip or sensor and mounts it on a small printed circuit board. This board then breaks out the tiny pins into easy to use, properly spaced headers. Most breakout boards also include helpful additions, such as voltage regulators, resistors, connectors or communication interfaces.
The result is a compact and user friendly module that you can plug into a breadboard, connect with jumper wires or integrate into a custom PCB without dealing with microscopic pins or complex circuitry.
Why breakout boards are convenient
Breakout boards are not just about making a chip easier to connect. They simplify electronics development in several ways and help you build projects faster and with fewer errors.
Clear labeling
Every pin on the breakout board is clearly labeled. Instead of checking datasheets or decoding pin numbers on the IC package, you can instantly see which pins are power, ground, inputs, outputs or communication lines.
This is extremely helpful when an IC has multiple pins that look identical but perform very different functions. Clear labeling reduces wiring mistakes and makes your project easier to debug if something goes wrong.
Small size and efficient layout
Breakout boards typically use SMD components, which means the actual sensor or IC is much smaller than older through hole versions. This saves space on your breadboard and leaves room for other components.
Traditional DIP package ICs take up much more space and are becoming less common. Breakout boards give you access to modern components without sacrificing breadboard compatibility.
Reusable and durable
Pins on DIP chips can bend or weaken after repeated breadboard use. In comparison, breakout boards are designed with durability in mind. Their headers are sturdy, and the board itself can be plugged in and removed many times without damage.
This makes breakout boards ideal for prototyping, classrooms, workshops and rapid experimentation.
Making new components accessible
Manufacturers increasingly produce sensors and chips only in surface mount form. Many modern sensors, accelerometers, pressure sensors and environmental modules do not come in breadboard friendly packages at all.
Breakout boards bridge that gap. They make tiny, advanced components available to hobbyists without requiring specialized soldering equipment.
[IMAGE PLACEHOLDER 2]
Things to watch out for when choosing a breakout board
Breakout boards are simple to use, but there are a few important details to keep in mind when shopping for them or integrating them into your project.
Not all breakout boards are interchangeable
Sometimes you will find a cheaper version of a breakout board online. It may look similar at first glance, but the internal chip might be different from the one you are expecting. Even if two boards perform similar tasks, their pinout or communication protocol may not match.
If you want to use prewritten libraries or example code, make sure the breakout board uses the exact same IC as the one the software was designed for. Using a different IC can lead to errors or unexpected behavior.
Header pins may or may not be included
Some breakout boards come with pre soldered header pins. Others include the pins in the package but require you to solder them yourself. A few come without pins entirely, leaving you to purchase the headers separately.
Always check what is included before buying, especially if you do not have a soldering iron or prefer plug and play solutions.
Use the correct supply voltage
Most breakout boards run on 3.3 V or 5 V. Some can accept both, while others are strictly limited to one voltage. Connecting a 3.3 V board to a 5 V supply can damage it.
Voltage labels are usually printed on the PCB, but if not, check the product documentation to avoid damaging your sensor.
Good documentation matters
High quality documentation can save you hours of frustration. A good breakout board should come with:
Clear pin descriptions
Example wiring diagrams
Sample code
Library support
Explanations of key features
Manufacturers who invest in documentation make it easier for beginners and advanced users to get started quickly. If documentation is missing or unclear, the board may be harder to integrate into your project.
Breakout boards vs Arduino shields
If you are familiar with Arduino shields, you may wonder how breakout boards differ from shields and when to choose one over the other.
Shields are designed to plug directly onto an Arduino board and often cover the entire board for convenience. They also tend to include many extra components because they are built for specific use cases.
Breakout boards, on the other hand, are much smaller. They focus on providing access to a single chip or sensor and leave the rest of the design flexible. You can use them with any microcontroller platform such as Arduino, Raspberry Pi, ESP boards or other development systems.
A breakout board designed for Arduino will generally work just as well with other platforms, while an Arduino shield will not align with other boards physically or electrically.
Shields and breakout boards both have value, but breakout boards offer more flexibility, take up less space and are usually more affordable.
[IMAGE PLACEHOLDER 3]
When to use breakout boards
You will want to use breakout boards when:
You need a compact sensor or IC that cannot plug into a breadboard
You want to reuse components across many projects
You want clearly labeled, easy to understand pin connections
You need stable, durable connectors for prototyping
You want access to modern components only available as SMD packages
Breakout boards speed up experimentation and let you focus more on your project and less on wiring challenges.
Getting started with breakout boards
If you want to begin working with breakout boards, you are in luck. There are breakout boards for almost everything:
Temperature and humidity sensors
Pressure and altitude sensors
Motion and acceleration modules
Light, gas and environmental sensors
Communication chips
Power and voltage monitoring modules
Audio and microphone systems
Most breakout boards include sample code, wiring diagrams and libraries to get you started quickly. If you are new to electronics, they are one of the easiest ways to expand the capability of your microcontroller board.
You can browse tutorials, libraries and community projects to find inspiration, learn new techniques and share your own builds.
Why breakout boards are essential for modern prototyping
Breakout boards make electronics accessible, flexible and modern. They reduce wiring complexity, save space, eliminate compatibility issues and help you integrate advanced components without specialized knowledge.
Whether you are experimenting with new sensors, building a product prototype or exploring new areas of electronics, breakout boards give you the freedom to innovate faster and build more reliable circuits.
If you are looking for breakout boards for your next project, explore our selection of sensors, adapters and modules designed to work smoothly with Arduino, Raspberry Pi and other development platforms.
