What is a breadboard and how to use it?
19.01.2026
This article explains what a breadboard is, how it is built internally, how to use it to connect components, and what its main advantages and limitations are.
Arduino
Raspberry Pi
IntroductionSolderless breadboardBreadboard internal structureTop of a breadboardPower rails or bus stripsTerminal stripsConnecting components on a breadboardJumper wiresPros and cons
If you want to make an electronics project, you will need something to connect your circuit on. Sure, you could solder everything together, but what if you’re just testing something? Or if the project you’re working on is temporary, and you plan on using the parts for something else? You would then use a breadboard.
Introduction
A breadboard is a construction base for electronics prototyping. It might look like a regular plastic board with many tiny holes in it, but it’s much more than that. It is one of the main tools for circuit building and electronics in general.
A solderless breadboard is as simple a device as it gets. It’s the most used device when creating temporary circuits. It is called solderless because no soldering is required, you can just plug in the components. A component can easily be removed from a breadboard if you make a mistake, or when starting a new project. This makes it great for both beginners who are just starting to learn about electronics and seasoned professionals.
If you’ve never worked with it before, you might wonder which holes do what. Let’s take a look at the bottom of a breadboard so you get a better idea of what’s going on.
Seeing it like this, you’ll get a better picture of how it works. The smaller metal platings are used for connecting components into your circuit. Rows are not interconnected. Two larger metal platings, perpendicular to smaller ones, are used to connect the board to a power source. That’s why they are referred to as power strips or rails (sometimes called bus strips).
If you were to take the metal platings out, you would see that they are actually little metal clips. They’re designed to grab the legs of components pushed through holes on the top side of the breadboard. Because they’re made from a conductive metal, you can test circuits without any soldering. Hence, the name solderless. All breadboards operate like this, no matter the size.
Top of a breadboard
Looking at the breadboard from the top side, you’ll see a bunch of little holes. This is where the legs of components go, and the clips inside grab on them. The spacing between these holes is 2.54 mm (0.1 inches). It is aligned with the spacing between the legs of most electronic components and integrated circuits.
The holes are divided into two areas called strips. These strips are made from interconnected electrical terminals.
Power strips (bus strips) are on the sides of the breadboard. They are used to provide electric power to the electronic components. They usually contain two columns – one for ground and one to supply voltage. The row indicating ground is normally marked blue or black, while the row indicating voltage supply is marked red. Along with colors, a ground column is indicated with a minus (-), and a voltage column is indicated with a plus (+).
Power rails generally go from one end of the breadboard to another. The holes are set in groups of fives. On large breadboards, however, the power rails are often broken in two.
Terminal strips
The main areas, those between the power rails, are used to hold most of the electronic components. As power rails, terminal strips are also divided into two columns, with a small ravine between them.
The rows are marked with numbers from 1 to as many as the breadboard design has. The columns are marked with A, B, C, D, E on one side of the board, and F, G, H, I, and J on the other side. Only five components can be connected in each row.
Wait, the row has ten holes, so why can you connect only five components? Notice that each horizontal row is separated by a ravine, or crevasse, in the middle of the breadboard. This ravine isolates both sides of a given row from one another, and they are not electrically connected. Thus, a hole on one side is not electrically connected to a hole on the other side.
Take a look at the picture below. You’ll get a clear idea of which hole connects to which.
Many integrated circuits (aka ICs or chips) are developed to fit onto breadboards. Since they tend to be larger than other components, they come in the so-called dual in-line package (DIP or DIL). That minimizes the amount of space they take on the breadboard. The ICs fit perfectly over the ravine. One side of the legs connects to column E, and the other side connects to column F. This way the legs of the ICs don’t interfere with each other’s functionality.
Components have long metal legs called leads used to get the electrical current to the component. Just put these legs through the holes and that’s it! The metal clips below will grab onto them and make them electrically connected to anything else in that row.
Make sure to push them all way through, until they can’t go any further. A lot of beginners will push the legs partially into the breadboard can, in turn, lead to strange circuit behavior, like LEDs flickering or not working at all, etc. The components can get damaged this way, so it’s always better to firmly push them down all the way.
Jumper wires
To connect the components to each other, Arduino or a power source, we’ll need some wires. Jumper wires are a type of wires that are used with the breadboard. There are two types most commonly used: Dupont-style and U-shaped.
Dupont-style wires come in three varieties, depending on their ends: male/male, male/female and female/female. They are very flexible and easy to work with, which is why they are often included in starting kits.
U-shaped wires are simply wires with insulation stripped at both ends and bent at a 90-degree angle.
Wires come in different colors, but they don’t mean anything. There are some color-coding disciplines that you can adhere to for consistency, though. For example, you can use red and blue or black for supply voltages and ground. Use a different color for the main signals, and the rest how you see fit.
Pros and cons
Pros:
  • inexpensive
  • it’s reusable, no soldering is required
  • changes to a circuit are simple to make by plugging components in and out
  • easy circuit construction
  • fast and easy way to get prototypes up and running
  • a variety of electronic components can be used
Cons:
  • not suitable for long-term connections due to them not being soldered
  • limited to operating at relatively low frequencies
  • not suitable for high current flow (the current limited to ~2 A with a good quality breadboard)
  • depends on high-quality contacts so connections don’t lag
  • usually can’t accommodate surface-mount devices or components with grid spacing other than 2.54 mm (0.1”)
  • connections have higher impedance than soldered connections
  • not suitable for components that rely upon a large ground plane connection
  • places limitations on how closely components can be placed
When just looking at the bullet points, it wouldn’t be unjustified to think you shouldn’t use a breadboard. The cons list is longer, after all. But pros outweigh the cons in this situation. The breadboard is just too useful for it not to be used in most cases. Unless you’re making a large project or something that must stay connected at all times, you can stick to using a breadboard for your projects.
