Every great electronics project starts somewhere.
Maybe it's a weather station that tells you if it's going to rain. Maybe it's a smart home sensor that automates your lights. Or maybe it's a robot, IoT device, or custom dashboard you've been wanting to build for months.
Whatever the idea, there's a good chance a development board will be at the center of it.
Development boards make it easy to turn ideas into working prototypes. Instead of designing complex circuits from scratch, you can focus on building, experimenting, and learning. That's why they've become one of the most important tools in the maker community, helping beginners get started while giving experienced developers a platform for testing and creating new projects.
In this guide, we'll explain what a development board is, how it differs from a microcontroller, the types of development boards available today, and how to choose the right one for your next project. Whether you're building your first blinking LED circuit or your tenth smart home device, understanding development boards is one of the best places to start.
What is a development board?
A development board is a circuit board designed to make it easier to program, test, and prototype electronic projects.
Think of it as a ready-to-use platform that gives you access to a microcontroller or processor along with the components needed to power it, program it, and connect it to other hardware. Instead of building a complex circuit from scratch, you can start experimenting and developing your project right away.
Development boards exist to remove many of the barriers that would otherwise make electronics development more difficult, especially for beginners. They provide a practical way to learn, prototype, and test ideas before committing to a custom hardware design.
Without a development board, you'd typically need to:
- Build a more complex hardware setup
- Add separate power regulation circuits
- Connect external programming hardware
- Wire additional components just to get started
- Troubleshoot low-level hardware issues before writing any code
By integrating these essentials onto a single board, development boards allow makers and engineers to spend less time on setup and more time building projects.
What components are found on a development board?
At first glance, most development boards look like a collection of chips, connectors, and pins mounted on a small circuit board. In reality, each component serves a specific purpose that makes development faster and easier.
Understanding these components can help you choose the right board for your projects and make better use of its capabilities.
Microcontroller or processor
The microcontroller or processor is the brain of the development board. It runs your code, processes inputs from sensors, and controls connected hardware.
For most maker and IoT projects, you'll encounter microcontrollers such as the ESP32, which are designed to perform specific tasks efficiently while consuming very little power. More powerful boards may use processors capable of running operating systems and handling advanced applications.
The performance of the microcontroller often determines what your project can do. A simple temperature monitor has very different requirements than a smart home dashboard, robotics project, or edge AI application.
USB connection
The USB port is one of the most frequently used features on a development board.
It allows you to:
- Upload code from your computer
- Power the board during development
- Monitor serial output for debugging
- Communicate with connected devices
Without a built-in USB connection, programming a microcontroller would often require additional hardware and a more complicated setup. This is one of the reasons modern development boards are so beginner-friendly.
Power management
Every electronic project needs stable power, and development boards include circuitry that helps manage it safely.
Power management components typically handle:
- Voltage regulation
- USB power input
- Battery connections on supported boards
- Power distribution to connected peripherals
This means you can focus on building your project rather than designing complex power circuits from scratch.
GPIO pins
GPIO stands for General Purpose Input/Output, and these pins are what allow a development board to interact with the outside world.
GPIO pins can be used to connect:
- Sensors
- LEDs
- Buttons
- Relays
- Motors
- Displays
Depending on your program, a GPIO pin can either read information from a device or control it. This flexibility is what makes development boards suitable for such a wide variety of projects.
If you've ever seen an LED blink as a first programming project, there's a good chance it was controlled through a GPIO pin.
Wireless connectivity
Many modern development boards include built-in wireless communication features, eliminating the need for additional modules.
Common connectivity options include:
- Wi-Fi
- Bluetooth
- Bluetooth Low Energy (BLE)
- Matter
- Thread
Built-in wireless connectivity makes it possible to create smart home devices, remote sensors, connected displays, and IoT applications with far less hardware than was required just a few years ago.
Common development board types and examples
Not all development boards are built for the same purpose.
Some are designed to help beginners learn programming and electronics. Others focus on wireless communication, smart home projects, or more advanced applications that require greater processing power.
The good news is that you don't need to understand every type of board before getting started. Most makers eventually find themselves gravitating toward a handful of popular platforms depending on the projects they want to build.
Arduino boards
For many people, Arduino is where the maker journey begins.
Arduino boards became popular because they made electronics accessible to people without an engineering background. Instead of worrying about complex hardware details, beginners could focus on writing code, connecting components, and seeing immediate results.
The Arduino Uno R4 WiFi continues that tradition while adding built-in wireless connectivity, making it easier to build connected projects without additional hardware.
If your goal is to learn how sensors, buttons, LEDs, motors, and displays work together, Arduino remains one of the easiest places to start.
The Arduino Uno R4 WiFi is a great choice for beginners who want to learn electronics while having room to explore IoT projects later on.
ESP32 boards
As projects become more connected, many makers eventually move toward ESP32-based boards.
The biggest advantage of the ESP32 family is that Wi-Fi and Bluetooth are built in from the start. Instead of adding separate communication modules, you can focus on building devices that interact with phones, cloud services, and smart home platforms.
Boards such as the NULA Mini ESP32-C6 take this even further by supporting modern standards like Matter and Thread, making them particularly attractive for smart home development.
Today, ESP32 boards power everything from weather stations and energy monitors to smart door sensors and custom Home Assistant integrations.
Raspberry Pi boards
Sometimes a microcontroller isn't enough.
Projects that need more memory, more storage, or more complex software often benefit from the Raspberry Pi ecosystem. Raspberry Pi boards are popular because they blur the line between a development board and a full computer.
The Raspberry Pi Pico 2 offers a lightweight microcontroller-based option, while larger Raspberry Pi boards can run complete operating systems and handle demanding applications.
They're frequently used for automation servers, media projects, monitoring systems, and educational environments where flexibility matters more than power efficiency.
Product highlight: The Raspberry Pi Pico 2 is well suited to embedded projects that need strong performance while remaining simple and affordable.
FPGA development boards
FPGA boards are a very different category.
Instead of programming a processor to perform tasks, you're effectively defining how the hardware itself behaves. This makes FPGA development incredibly powerful but also considerably more advanced than working with traditional microcontrollers.
Most makers won't start with an FPGA board, but they're widely used in engineering, research, digital signal processing, and custom hardware development.
If you've ever wanted to go beyond software and explore how computer hardware actually works, FPGA platforms offer that opportunity.
IoT development boards
The rise of connected devices has created a category of development boards specifically designed for IoT applications.
These boards prioritize wireless communication, low power consumption, and easy integration with cloud services and smart home ecosystems.
Many modern ESP32 boards naturally fall into this category. The NULA Mini ESP32-C6, for example, combines Wi-Fi, Bluetooth, Matter, and Thread support in a compact form factor that works well for battery-powered and always-connected projects alike.
Whether you're building a smart thermostat, tracking environmental conditions, or creating a custom smart home device, IoT-focused boards provide many of the features you need straight out of the box.
Why Soldered development boards are great for makers
Choosing the right development board can make the difference between a project that gets finished and one that gets abandoned halfway through.
That's why Soldered focuses on creating hardware that's approachable for beginners while remaining powerful enough for more advanced projects. Whether you're learning electronics for the first time, building a smart home device, experimenting with IoT, or developing a custom prototype, the goal is to help you spend less time troubleshooting and more time creating.
From versatile boards like the Nula Mini to a growing ecosystem of easyC-compatible sensors and modules, Soldered products are designed to make development faster and more enjoyable. Instead of dealing with complex wiring and setup, you can focus on bringing your ideas to life.
The best development board is ultimately the one that helps you start building. With the right board, a simple idea can quickly become a working prototype, a useful tool, or even the foundation for your next big project.
Frequently asked questions about development boards
A development board is a circuit board designed to make it easier to program, test, and prototype electronic projects. It typically includes a microcontroller or processor, power management circuitry, programming interfaces, and connectors for external components.
What is the difference between a development board and a microcontroller?
A microcontroller is the chip that runs your code, while a development board includes the microcontroller along with the supporting hardware needed to power, program, and connect it to other devices. Development boards make it much easier to start building projects without designing custom circuits.
What are development boards used for?
Development boards are used for learning electronics, prototyping new products, building IoT devices, creating smart home projects, robotics, automation systems, environmental monitoring, and countless other applications.
Which development board is best for beginners?
Arduino boards are often recommended for beginners because they are easy to use and have a large community of tutorials and resources. Boards like the Arduino Uno R4 WiFi provide a great introduction to programming and electronics.
Is ESP32 a development board?
ESP32 is a microcontroller family, but many manufacturers build development boards around ESP32 chips. Examples include the ESP32 DevKit and the Nula Mini which add USB connectivity, power management, and expansion interfaces to simplify development.
What can I build with a development board?
You can build a wide range of projects, including weather stations, smart home devices, robots, data loggers, environmental sensors, connected displays, energy monitoring systems, and IoT applications.
Do development boards include Wi-Fi and Bluetooth?
Many modern development boards include built-in wireless connectivity. ESP32-based boards commonly offer Wi-Fi and Bluetooth, while newer models may also support technologies such as Matter and Thread for smart home development.
