What is a MOSFET
19.01.2026
This article explains what a MOSFET is, how it works, the main types, typical applications, and how to choose the right MOSFET for microcontroller and power projects.
Arduino
What is a MOSFET
IntroductionWhat is a MOSFETMOSFET as a variable resistorTypes of MOSFETsWhat MOSFETs are used forExample project ideas with MOSFETsChoosing the right MOSFETWhy MOSFETs matter in electronics
Introduction
When working with modern electronics, one component appears everywhere from beginner kits to advanced power circuits. It is the MOSFET. If you have opened a starter set or browsed through common modules, you have likely seen a small three pin transistor marked with terms such as Gate, Drain and Source. But what exactly is a MOSFET, and why is it used so often?
MOSFETs are essential building blocks in digital electronics, power control, motor drivers, switching regulators and countless everyday devices. In this article, we explain what a MOSFET is, what makes it special and where you will encounter it in real world applications.
What is a MOSFET
MOSFET stands for Metal Oxide Semiconductor Field Effect Transistor. It is a type of transistor that controls current flow using voltage rather than current. This makes it different from the classical bipolar transistor, which requires continuous current to drive it.
A MOSFET has three pins:
  • Source
  • Drain
  • Gate
The Source and Drain are connected through a semiconductor channel. The Gate controls how easily current can pass through that channel. When a certain voltage is applied to the Gate relative to the Source, the channel starts conducting. Without this voltage, the channel has very high resistance and behaves like an open switch.
This simple principle is the reason MOSFETs are so widely used. They act as fast, efficient electronic switches that can control high currents using only a small voltage signal.
One important detail is that the Gate is isolated from the channel by a very thin oxide layer. This allows the MOSFET to be voltage controlled, but it also makes the Gate sensitive to static electricity. Even a small electrostatic discharge can damage the oxide layer, which is why careful handling is recommended.
Although MOSFETs are often used as switches, you can also think of them as variable resistors. With no voltage on the Gate, resistance between the Source and Drain is extremely high, sometimes in the megaohm range. This is similar to an open circuit where almost no current flows.
When you apply the required Gate to Source voltage, the resistance quickly drops and current begins to flow. The higher the Gate voltage, the stronger the conduction. This behavior makes the MOSFET useful for controlling motors, LEDs, heaters and other loads where smooth regulation or rapid switching is required.
Types of MOSFETs
P channel and N channel MOSFETs
The two most common MOSFET types are P channel and N channel. Their internal structure is different, and so is the required Gate voltage.
  • An N channel MOSFET requires a positive Gate to Source voltage to turn on.
  • A P channel MOSFET requires a negative Gate to Source voltage to turn on.
In practice:
  • N channel MOSFETs are typically used on the low side of a circuit.
  • P channel MOSFETs are typically used on the high side.
N channel devices tend to have lower resistance and better overall performance, which is why they are more common in most electronic designs.
Enhancement and depletion MOSFETs
MOSFETs also come in enhancement and depletion versions.
  • Enhancement MOSFETs only conduct when a voltage is applied to the Gate. They function like normally off switches.
  • Depletion MOSFETs conduct by default and require Gate voltage to reduce or stop current flow. These are less common in hobby electronics but appear in some specialized circuits.
MOSFETs are everywhere because they switch quickly, operate efficiently and require very little control power. They allow small microcontrollers to handle large loads safely.
Digital electronics
Modern CPUs, memory chips and integrated circuits rely on enormous numbers of tiny MOSFETs to perform logic operations and store data.
Power switching
MOSFETs are common in power supplies, voltage converters, LED drivers and battery based electronics due to their high efficiency.
Motor and load control
From DC motors to LED strips and heaters, MOSFETs let microcontroller systems control large loads with precision.
Amplification
Radio frequency systems use MOSFETs as amplifiers because they can operate at high frequencies.
Everyday electronics
They appear in laptops, smartphones, automotive systems, home appliances and virtually every modern electronic device.
If you want to experiment with MOSFETs, here are some practical and approachable project ideas:
  • Controlling LED strips with PWM
  • Switching a DC motor using a microcontroller
  • Designing a simple power regulator
  • Driving a heating element or Peltier cooler
  • Building an automated fan controller
These projects highlight how flexible MOSFETs are and how easily they fit into Arduino, ESP and other microcontroller setups.
Picking the correct MOSFET is important for efficiency, safety and compatibility with your microcontroller. Consider these parameters:
Gate threshold voltage (Vgs th)
Indicates the voltage required to begin conduction. Logic level MOSFETs are ideal for 3.3 V or 5 V microcontrollers.
Drain to Source resistance (Rds on)
Lower values mean lower heat dissipation and better efficiency.
Max Drain current (Id)
The maximum current the MOSFET can safely handle.
Max voltage (Vds)
The highest voltage the MOSFET can block when off.
Package type
Through hole MOSFETs are easier to prototype with. SMD types are compact and used in production designs.
MOSFETs combine high efficiency, fast switching and minimal control power. They allow low power microcontrollers to control motors, lights, heaters and other components that operate at higher currents or voltages. This makes them essential in both simple DIY projects and advanced electronics design.
Whether you are experimenting with your first electronics kit or developing your own hardware products, understanding MOSFETs opens up new possibilities.
If you are looking for MOSFET modules, drivers or adapters, explore the growing selection available in our store. They are designed to help you prototype faster and build more reliable projects.
