WiFi Motion Alert System using PIR sensor
19.01.2026
This article explains how PIR motion sensors work, what delay time means, and how to read DOUT/SOUT outputs. It includes an Arduino serial example and an ESP32 WiFi project that hosts a web page and sends an email alert when motion is detected.
Inkplate
Arduino
Raspberry Pi
IntroductionHow does it work?Delay timeDetecting movementPIR WiFi Alert project
Introduction
Motion sensors are all around us, quietly keeping spaces secure and responsive without us even noticing. From automatic hallway lights that switch on as you walk by, to alarm systems that detect unexpected movement, to motion-activated security camera networks - PIR (Passive Infrared) sensors play a major role in everyday automation and security. Once found mostly in commercial products, as DIY electronics projects became more capable, components like PIR sensors are now available as simple plug-and-play modules available to anyone.
This article will walk you through what PIR sensors are, how do they detect motion, and finally how you can set your microcontroller to perform a certain task such as turning on a light or sending a notification based on whether motion was detected.
How does it work?
A Passive Infrared sensor is an electronic device that detects a moving object as it enters its field of view, causing a change in infrared levels. All objects and people that radiate heat also give off a low level of infrared radiation, relative to their temperature. The hotter the object, the more radiation it emits.
These devices are centered around two balanced strips of pyroelectric material which are placed parallel to one another, thus creating a pyroelectric sensor. This detects thermal energy in the surrounding area. In addition, an infrared filter is also included to block out all other light wavelengths. So, once a change to the signal differential between two pyroelectric elements is detected, the PIR sensor then triggers and sends a signal.
Delay time
One important concept about PIR motion sensors is the dwell time (sometimes called “delay time”), which is the amount of time the sensor’s output stays HIGH after detecting motion. In more simpler terms, it’s how long the sensor keeps reporting “motion detected” before returning to LOW.
Some PIR sensors models can have a small onboard potentiometer that lets you adjust the sensor delay. This is important because it helps avoid false triggers or rapid on/off cycling, it is also useful in lightning or security systems where you would want a stable “motion detected” signal.
Detecting movement
After understanding the basics, we’ll create a simple example that will print out a message to the serial monitor when motion is detected. Our PIR movement sensor board comes in two variations:
  • Standard version - uses DOUT and SOUT pins for output
  • I2C version - uses Qwiicy/easyC connector for easy connection (default address 0x30)
Example: Simple motion detection with delayed output
#define SOUT_PIN 2
#define DOUT_PIN 4
// Variables that hold the time since the last measurement for specific pins
unsigned long dout_delay = 0;
unsigned long sout_delay = 0;
  // Set the pins as input
  pinMode(DOUT_PIN, INPUT);
  pinMode(SOUT_PIN, INPUT);
  Serial.println("Warming up sensor...");
  // Wait 20s so the sensor can warm up
  delay(20000);
  Serial.println("Warmup done!");
  // If the pin is set to HIGH and at least 4s have passed since the last measurement, print detection
  if (digitalRead(DOUT_PIN) && millis() - dout_delay >= 4000)
    Serial.println("DOUT Motion detected!");
    dout_delay = millis();
  if (digitalRead(SOUT_PIN) && millis() - sout_delay >= 4000)
    Serial.println("SOUT Motion detected!");
    sout_delay = millis();
As you can see from the serial monitor output, the DOUT pin passes the 4 second delay threshold which we set, this is because the pin gives a HIGH (“motion detected”) reading for an additional 2 seconds when the onboard potentiometer is set to the highest delay (counter-clockwise). Adjusting this value can be useful for projects when creating a motion detector that is not too sensitive to small movements.
Components used:
  • ESP32
  • PIR sensor module
  • LED
  • 330 Ohm resistor
This project uses WiFi capabilities of ESP32 to send an email alert notification when movement was detected, the email contains date and time the movement was detected. Additionally, notifications can be turned ON/OFF from a web server built from ESP32. To access it, first make sure you are connected on the same network as ESP, then just type in the IP address printed on the serial monitor in your web browser URL.
Below is the key logic showing how the loop handles interrupts and triggers the email notification:
  // Handle incoming client requests for the web server
  server.handleClient();
  // If motion is detected (set by ISR) and at least 4 seconds have passed from last detection
  if (motionDetected)
    // Reset the flag safely
    noInterrupts();
    motionDetected = false;
    interrupts();
    const unsigned long now = millis();
    // Debounce/Delay check
    if (now - lastHandledMS >= 4000)
      lastHandledMS = now;
      Serial.println("MOTION DETECTED");
      updateTime(); // Sync time for timestamp
      // If notifications are enabled via web UI, send alert email
      if (notificationsEnabled)
        sendMotionNotification("Movement detected on " + print_last_detection_time() + "!!");
// Interrupt Service Routine (ISR) for PIR sensor
void IRAM_ATTR onPIRDetection()
  motionDetected = true;
The main loop logic first checks whether any device has made an HTTP request to the ESP32 board. Then, if motion was detected and at least 4 seconds have passed since last time motion was handled, it updates the timestamp, prints a corresponding message and sends a motion-alert email if notifications are enabled.
Web page + email notification:
Successful message output:
