This, of course, makes sense when we use the same digit more often than it is used in this example. These same functions can be put into library and be called when desired. Check out our tutorial about how to make your own Arduino library which controls these displays.
7 SEGMENT DISPLAY
WHAT ARE THOSE?
Seven segment displays or seven segment indicators are popularly referred to as the old-school way of displaying Arabic numerals. Multiple characters can be displayed on the 9, 14 or 16 segment displays. Alternatively, there are similar screens which display other symbols, such as LED matrices.
Their name is obtained by being composed of 7 segments, which is seen in the picture above. Three of them are horizontal, and four vertical. Each segment is illuminated by LCD or LED technology. Actually, there are many ways to illuminate segments, for example very popular nixie lamps.
HOW DO THEY WORK?
Let’s stick to modern LED 7 segment displays. For starters, we will divide them into those with mutual cathode(-) and anode(+). It is simple, we will connect the displays with mutual cathode to the gnd pin, and then, using digitalWrite(pin, HIH); trigger the display’s segment and vice versa. Soon, in more detail.
The image above shows the display’s pins, a total of 10. The middle upper and lower pin refers to the mutual cathode, i.e. anode, depending on the model. 8 remaining ones are left for 7 segment display plus the spot which is in the lower right corner. Let’s check the pinout:
The pinout refers to the display with mutual cathode and shows which pin triggers which segment. For example, we connect the (-) pin to (-) battery’s pole, and pin8 through the resistor with + pole and the spot will light up.
If we use the display with mutual anode, we switch the poles and get the same thing.
Of course we will not relocate the cables for every sign we want to display so let’s connect everything to Croduino.
CONTROLLING WITH CRODUINO
For starters, let’s connect the pins to Croduino as shown in the picture. NOTE: here we use the display with mutual cathode, if you have a mutual anode, for now, just connect +5V off the Croduino to pins which are connected to the black cable (gnd).
Here is a small connecting table:
There is no specific reason why we have chosen these pins, feel free to choose which ever you like. If your display takes up too many pins, consider using the shift register.
What and how to display?
The image above shows some of the symbols we can “activate” on the display. Let’s repeat the logic once more using the table:
Numbers 0 and 1 indicate both on and off, i.e. 0-LOW and 1-HIGH. Again, this applies to displays with a mutual cathode. If you use a mutual anode, simply replace zero and one.
Let’s write down one concrete Arduino code. We will turn on number 1, and after half a second, number 2.
// we will make a small loop which turns pins from 2 to 9 into output pins
for
int
i=2; i<=9; i++)
pinMode
(i,
OUTPUT
// turning number one on
digitalWrite
(5,
HIGH
digitalWrite
(8,
HIGH
// pause 500ms = 0.5s
delay
(500);
// shutting down the remaining characters on the display
// in order for them not to mix with digit two
digitalWrite
(5,
LOW
digitalWrite
(8,
LOW
// turning number two on
digitalWrite
(2,
HIGH
digitalWrite
(4,
HIGH
digitalWrite
(5,
HIGH
digitalWrite
(6,
HIGH
digitalWrite
(7,
HIGH
// another pause so that we manage to registrate
// the change before the loop starts over
delay
(500);
// shutting down number two segments
digitalWrite
(2,
LOW
digitalWrite
(4,
LOW
digitalWrite
(5,
LOW
digitalWrite
(6,
LOW
digitalWrite
(7,
LOW
And so on for each digit. A very long code. One way to make it easier is to make a function for each character we use, and then call it whenever we want:
