HUM: RS485 MODULE
RS485 is a standard of physical connectivity for data transmission that defines electrical characteristics of serial communication. It can be used to connect 2 or more microcontrollers as well as various I / O devices that support this standard. The characteristics of this standard make it very useful in data transmission over large distances in industrial facilities where electric noise is more pronounced.
RS485:
• Allows serial communication over large distances (up to 1.2 km (100 kbps max))
• Differential transmission
• Half-duplex
• High transmission speed (up to 10 Mbit/s (12 m max))
• Enables the connection of multiple transmitters / receivers along the same cable – „Multi-Drop“
• Voltage levels: +/- 1.5V do +/- 6V
HOW DOES IT WORK?
Let us first get acquainted with the electrical characteristics of the RS485 communication. Unlike the familiar RS232 standard which uses a single-ended signaling mode, RS485 uses the differential signaling which has its advantages.
Single-ended signaling is the simplest and most commonly used method of transmitting electric signals over wires (R232, I2C, PS/2, WGA,..). One wire carries a varying voltage that represents the signal, while the other one is connected to a reference voltage (usually ground, 0V). This type of system is less expensive to implement than differential, but it lacks the ability to reject noise caused by the differences in ground voltages between transmitting and receiving circuits or induction on the signal wires.
The main advantage of single-ended over differential signaling is that fewer wires are needed to transmit multiple signals. If there are n signals, then we need n+1 wires (one for each signal and one for ground), while the differential signaling uses at least 2n wires.
As the main alternative to single-ended signaling, we use the differential signaling (RS485, HDMI, USB,…). This method sends differential pairs of signals, each in its own conductor. The receiving side responds to the difference in voltages between the two signals, rather than reading the signal level in relation to the reference level (ground). The reason why this type of technique is more resistant to noise than the single-ended signaling is the fact that any external electromagnetic noise will equally affect both signals and voltage difference will remain the same. This is why this standard is suitable for use in industry.
RS485 differential signaling (n signal, 2n wires)
RS485 allows multiple devices to communicate in both ways but not simultaneously (half-duplex), i.e. the communication is possible in both ways, but when one master device “speaks” all other slave devices “listen”. Also, RS485 can be configured in full-duplex mode that allows simultaneous communication in both directions, but it requires 4 wires which is a bit more expensive to implement.
Turnaround time: since communication takes place in one and the other direction through the same pair, the device which has sent data so far must switch to the receiver mode. When designing a system, it is important to keep an eye on the interval during which the device is changing its state. If the interval is too long, the device may miss the first (starting) bit or the first few bits essential for further communication, and an error occurs. Usually, the interval takes the duration of the transfer of 1 symbol, depending on the baud rate. The good news is that most converters automatically perform this transition, so the developer’s work is easier.
Termination resistors: when sending bits from one end of the cable to another, there is always a reflection of the voltage that returns along the cable and is larger when the raising edge is steeper (sharper) and when the transmission lines are longer. This negatively affects communication, and for such a phenomenon to be reduced, resistors between lines A and B are used. Their value should be equal to the characteristic impedance of the lines (typically 120 Ohms per pair).
The image that shows signals with non-adapted (left) and adapted resistance (right)
Also, when sending data, high-frequency components that cause electromagnetic interference also appear with the emergence of a rising edge. At higher transmission rates and longer transmission lines, it is even more pronounced, and because of this, the signal lines are usually used in pairs (twisted pair).
Bias resistors: With the RS485 networks, it may happen that at one time none of the devices send data. Then, the differential distinction between the transmission lines is 0V and this is an indefinite state for the receivers. Such a condition may cause inaccurate data in the receiver due to the noise collected on the transmission lines, and for that purpose, resistors are used to set the signal lines to the proper voltage in the voltage configuration of the divider.
Arrangement of bias and termination resistors at the ends of the wires
HOW TO CONNECT IT?
GND ————> GND
Vcc ————-> +5 V
RO ————-> Pin 7
RE ————> Pin 13
DE ————> Pin 13
DI ————> Pin 6
A ————> A
B ————> B
RO (receiver output) – a pin that registers the voltage difference between signal lines A and B, and it will be high if A>B for 200mV, and low if A<B for 200mV. It is the pin through which the microcontroller receives data (Rx)
/RE (receiver output enable) – when RE is low, RO is enabled, i.e. this device switches to the receiver mode. When RE is high, RO is in high impendance state and the device can not receive data
DE (driver output enable) – if DE is high, the device is in the transmitter mode, if DE is low, the device can not send data
DI (driver input) – a pin through which the microcontroller sends data (Tx,) if it is set to high, line A is at 0V, while line B is at 5V, and vice versa for low
The following code will allow interchangeable communication using two Croduinos. First #1 sends what we have written in the SerialMonitor, #2 reads it and sends back the same data. If both sent and received data are equal to what is written in the SerialMonitor, the communication process is successfully and seamlessly executed.
TRANSMITER #1
No products found
