HUM: SHT21 & SHT20 TEMPERATURE AND HUMIDITY SENSOR
Our new breakout contains the SHT21 temperature and relative humidity sensor, and communication with the microcontroller is enabled through the I2C communication. The sensor has become very popular due to its high precision and reliability. The sensor itself is made in Switzerland, where it is also calibrated and immediately ready for use. Each breakout board is made in Croatia which ensures the quality of making and simplicity of use.
Characteristics:
Power supply voltage: 5V
Relative humidity, measurement range: 0-100%
Relative humidity, precision: 0.04% (12 bit)
Temperature, measurement range: -40°C – 125°C
Temperature, precision: 0.01°C (14 bit)
Communication interface: I2C
Dimensions: 25 mm x 15 mm
HOW DOES IT WORK?
The sensor works as a slave in the I2C communication. At the request of the microcontroller, the sensor starts and begins a process of measuring temperature and humidity. When the sensor is done measuring, it sends the measured data to the microcontroller and goes into idle mode to ensure low energy consumption. Time spent measuring temperature and humidity varies between 5 and 30 seconds, which depends on thermal conductivity of the material which the sensor is in touch with. For example, the sensor will read the change of temperature if it is in touch with a good thermal conductor, such as metal, sooner than when it is in touch with a heat insulator.
HOW TO CONNECT IT?
Connectors:
gnd: ground
VCC: voltage 3.3V – 5.5V
SDA: serial data I2C
SCL: serial clock
In the image below, it is shown how to connect your new breakout to the Croduino microcontroller. Connecting is very simple and all you need is four wires, two of which you need for power supply, and two for communication. Power supply of the board is achieved by connecting the +5V connector and the gnd to the homonymous connectors of Croduino. It is still necessary to connect the SDA and SCL communication connectors to the homonymous connectors on Croduino.
No products found
