Back to Blogs
Best soldering kits for beginners: what to look for and top options in 2026
12.08.2026
What's actually happening when you solderReading a jointWhy every beginner kit is through-holeWhat to look for in a beginner soldering kitThe stuff the kit doesn't come withBeginner soldering kits worth building in 2026So which oneTwo things that go wrong the first timeThe short versionFAQ
Everyone's first solder joint looks like a blob. That's not a sign you're bad at this. It means you haven't built the feel for how long to keep the iron on the pad yet, and the only way to get that is to do it about fifty times.
Most beginner advice stops at "heat the pad, then add solder." True, but it doesn't tell you why the joint failed, so this guide goes at it from the other end: what's happening on the pad, how to read what you made, and only then which kit to buy. If you'd rather skip straight to comparing kits, we did that in our earlier post on the best soldering kits for beginners.
It isn't glue and it isn't welding
Welding melts the two parts and fuses them into each other. Soldering never touches that. The alloy melts at a much lower temperature, and where it meets clean hot copper, the tin in it reacts with the copper and grows a thin layer of copper-tin compound. A few micrometers thick. That layer is your joint. Everything sitting on top of it is leftover solder that delivered the tin and then solidified.
So what matters is getting the copper hot, not the solder. Heat the solder on its own and nothing reacts, which means you don't have a joint. You can melt solder on the tip, wipe it onto a cold pad, and get something that looks connected. It might even pass a test. Then it quits three weeks later and you spend an evening hunting through your code for a bug that was never there.
Flux is doing more than you think
Copper starts oxidizing the moment it hits air, and molten solder won't stick to oxide. It balls up and rolls around like water in a greasy pan. Flux gets rid of that film. It's a mild acid that activates at soldering temperature and keeps fresh air off the metal while the joint forms, and your solder wire already has it in the core, so for through-hole work you almost never need a separate flux pen.
Here's the part nobody mentions: flux burns off as it works. That's why reheating the same stubborn joint over and over makes it worse instead of better. First attempt, you've got flux. Fourth attempt, you're pressing molten metal against bare oxide and wondering what changed. Touch fresh wire to the joint instead and the flux comes along with it.
Temperature, and why more of it doesn't help
Sn63Pb37, the leaded stuff, melts at 183 °C. It's eutectic, so it goes straight from solid to liquid with no slushy phase in between, and that's most of the reason it feels so good to work with. Lead-free melts closer to 217 °C and stays gummy on the way back down.
Set the iron to 320 to 350 °C for leaded, 350 to 370 °C for lead-free. Cranking it to 450 does not make joints faster. It cooks the flux off in half a second and starts lifting pads off the board.
When joints are slow, the tip is usually the culprit. Heat travels through contact area, so a 2 mm chisel laid across the pad and the lead heats both in a second or two, while the point of a fine conical tip touches almost nothing and just sits there glowing at you. Big ground pours drink heat, and those pads want more tip, not a higher number on the display.
The rhythm ends up being: iron on the pad and the lead, count to two, feed solder for about a second, pull the wire away, then pull the iron away. Three seconds or so. If you're at ten, stop and look at your tip.
Reading a joint
The nice thing about through-hole work is that you can just look at it.
What you see What it means What to do
A small cone climbing the lead and spreading out to the edge of the pad Solder wetted both surfaces properly Nothing. Move on
A ball sitting on the pad with a visible edge where it stops Cold joint. The pad never got hot Reheat with the tip on pad and lead, add fresh solder
Gray and grainy, almost crystalline The board moved while it cooled, or the joint got cooked Reflow it and hold everything still for a few seconds
Dull but smooth Perfectly normal for lead-free Nothing
Solder spanning two pads A bridge. Too much solder, or the tip sat there too long Wipe the tip clean and drag it across, or use wick
Hole not filled, lead wiggles Not enough heat or not enough solder Heat from the other side of the board and feed a bit more
Cross-section diagram of six through-hole solder joints: a good wetted joint, a cold joint, a grainy disturbed joint, a solder bridge, an unfilled hole and an over-soldered blob
Click the diagram to open it full size.
The holes are plated, so capillary action pulls molten solder down through the barrel and you get a fillet on both sides of the board. Pads are big, spacing is 2.54 mm, and the parts sit in their holes by themselves while you work.
Surface-mount parts sit on top of the copper instead. An 0402 resistor is a millimeter long, about the size of the letter o you're reading. Plenty of people hand-solder them and you will too at some point, just not tonight.
There's a middle option worth knowing about. Some kits arrive with the SMD parts already machine-soldered and leave the through-hole ones for you. Make Your Own NULA is built that way.
  • Twenty to forty joints for a first build, mostly resistors, LEDs, buttons and headers. That's one evening, not a project that dies half finished in a drawer.
  • A placement diagram shows you where parts go. A schematic shows you why. The second one is what turns an assembled board into a board you understand.
  • A microcontroller that arrives programmed. If the firmware is already on there, the only thing that can go wrong is your soldering, so powering it up gives you a straight answer. You can always reflash it later when you get curious.
  • Clear polarity markings on the silkscreen. LEDs, electrolytic capacitors and diodes only go in one way. If that's new to you, our post on polarity in electricity covers it.
  • A socket for the main chip, so overheating it isn't the end of the board.
  • Something you'll keep switching on afterwards. A board that lives on your desk is the one that gets you to build the next thing.
  • Check the parts list for tools. Most project kits are PCB and components only.
None of this needs a fancy station. An adjustable iron around 60 W with a 2 mm chisel tip handles every kit we make. Add thin solder, 0.8 to 1 mm, like our Sn63Pb37 wire. Clean the tip on brass wool or a cleaning net rather than a wet sponge, which shocks the tip cold on every wipe. Then flush cutters, tweezers, something to stop the board sliding around, and solder wick for when you overdo it. You will overdo it.
Solder Wire 17g 1mm Sn63Pb37
Regular price  €2,95 Sale price  €2,21
Soldering Iron Tip Cleaning Net
€3,95
€3,95
On fumes: that smoke is flux, not lead. Lead doesn't evaporate anywhere near 350 °C. Flux is still what leaves you with a scratchy throat after an hour, so open a window or put a small fan behind the board blowing the smoke away from your face. Wash your hands when you're done and keep food off the bench.
Simon Says Game Solder Kit (Best first build)
Four LEDs, four buttons, a buzzer and an ATtiny404 that turns up already programmed in Arduino. It's the smallest build we make, and that's the whole point. Plug it in and it either plays the memory game or it doesn't, and if it doesn't, the problem is a joint you can find with your eyes. €7.95.
€7,95
€7,95
LED Dice, Reaction Game and Stop Me (Same level, different game)
Same price, same difficulty, different game, so pick the one you'd actually play with. LED Dice is the fastest of the three to finish. Reaction Game and Stop Me both get harder the better you do, which is why they keep ending up in classrooms. €7.95 each.
LED Dice Solder Kit
LED Dice Solder Kit
€7,95
€7,95
Reaction Game Solder Kit
€7,95
€7,95
Stop Me Game Solder Kit
€7,95
€7,95
Piano Solder Kit (Best step up)
Twelve keys with nothing mechanical underneath them. An ATmega328P reads the touch pads directly, one pot sets volume and the other sets arpeggio speed, and the whole thing runs off USB-C. Noticeably more joints than the games, and capacitive sensing is one of those things that feels like a trick until you've soldered one together yourself. €15.95.
Piano Solder Kit
Piano Solder Kit
€15,95
€15,95
Pomodoro Timer Solder Kit (Best second build)
Four digit seven-segment display, an RGB LED, a buzzer, and an RP2040 running MicroPython. The display alone gives you a long run of identical joints one after another, which is exactly where technique stops being a thought and turns into muscle memory. You also get a timer you'll use. €10.95.
€10,95
€10,95
Lo-Fi Noise Machine Solder Kit (Best for learning analog)
A 556 timer, a voltage boost stage, two pots and no code anywhere on the board. It's the old Punk Console circuit with a few modern additions, and jumpers let you send the sound to the onboard buzzer, the 8 ohm speaker in the box, or a jack. If you learn better by hearing what a circuit does than by reading about it, build this one. €11.95.
€11,95
€11,95
Macro Pad Solder Kit (Best one to keep using)
Five MX-compatible switches on a 7 by 7 cm board with an RP2040 running QMK. Play/pause, mute and volume are mapped out of the box, and everything is remappable in the QMK web configurator, so you never have to open a compiler. This is the one people still have on their desk a year later. €14.95.
Make Your Own NULA Solder Kit (Best full learning kit)
The SMD side is done for you. Yours is the through-hole side: capacitors, LEDs, the JST battery connector and the socket for the ATmega328P. What you end up with is a working Arduino-compatible board you can build your next project on, not a demo. Don't make it your first one. €14.95.
Side by side
Kit Price What it teaches Good for
Simon Says €7.95 Basic through-hole joints A real first build
LED Dice €7.95 LED polarity and orientation The shortest first build
Pomodoro Timer €10.95 Display wiring, MicroPython Second build with a use
Lo-Fi Noise Machine €11.95 Analog oscillators, no code Learning circuits by ear
Macro Pad €14.95 Switch soldering, QMK A tool you keep using
Make Your Own NULA €14.95 How a dev board goes together Third build onwards
Piano €15.95 Capacitive sensing, more joints A step up that sounds good
The rest of them are in the solder kits collection if you want to compare for yourself.
So which one
Never held an iron before: Simon Says or LED Dice. Cheap enough that wrecking one costs you nothing, and neither eats a whole evening.
Got one build behind you: the Piano Kit or the Pomodoro Timer, depending on whether you'd rather make noise or watch a display count down.
Want to keep what you made: the Macro Pad, or NULA if you'd rather have a board to build on.
Nothing happens when you plug it in. Before you suspect anything clever, hold the board under a bright lamp and look at every single joint. Cold joints are almost always the answer, and they're hard to spot precisely because they look finished.
A pad came off with the component. The board is usually still fine. Run a short piece of wire from the leg to the next point on that trace. It looks terrible and it works.
The short version
Heat the copper, respect the flux, three seconds instead of ten. That's most of what separates a joint that holds from one that doesn't, and it matters more than what you spent on the iron. Buy the cheapest kit that makes something you'd actually switch on, build it in one sitting, then hold it up to a lamp and look at your joints properly. The second board always looks better than the first.
FAQ
Do soldering kits for beginners include a soldering iron?
Usually not. A project kit is the PCB, the components and the instructions, and it assumes you have tools. Anything sold as a soldering iron kit is the opposite: tools, nothing to build.
What temperature should I set my iron to?
320 to 350 °C for leaded solder, 350 to 370 °C for lead-free. If joints feel slow, switch to a wider tip before you touch the temperature.
Leaded or lead-free for a first kit?
Leaded Sn63Pb37 is easier to learn on. It melts lower and flows more predictably. Lead-free is what you want for anything you sell, and it's worth moving over once your technique is steady.
How long does it take to get decent at this?
Most people are making reliable joints inside their first hundred, which is two or three small kits. It clicks faster than you'd expect once you can see the difference between a wetted joint and a ball of solder sitting on a pad.
Can I practice without a kit?
Sure. A protoboard and a bag of cheap resistors will do it, and it's a useful step between a breadboard prototype and a proper soldered build. We compared those two board types in breadboards vs perfboards.
Are these kits okay for kids?
With an adult at the table, yes. The tip runs above 300 °C. The simpler game kits get used in school workshops all the time.
Every joint looks fine and it still doesn't work. Now what?
Go through the placement diagram part by part, watching anything polarized and every resistor value. A swapped resistor and a backwards diode both look completely normal at a glance.
