Back to Blogs
15 fun Arduino projects for kids to build in 2026
28.08.2026
Why Arduino is great for kids15 fun Arduino projects for kidsWhich Arduino components should kids learn first?Choosing the right Arduino board for kidsWhy Soldered is a great place to start learning ArduinoTakeaways before you start buildingFrequently asked questions
Theory is a hard sell to a nine-year-old. A light that blinks because they programmed it is not.
Effective Arduino project guides for kids rely on direct feedback: a child changes a line of code, and the board responds. Beginners can start with zero prior experience, using step-by-step guides to learn coding and basic electronics. They can watch the circuit work, modify a single parameter, and observe the immediate change.
The Arduino platform was created as an accessible tool for students, offering a low-cost way to build devices that sense and react to the physical environment. Two decades later, its accessible design allows beginners and experienced makers to work with the same hardware.
The 15 builds below are ordered sequentially, with each project introducing a single new concept.
Arduino uses a beginner-friendly development board to connect electronic components and execute control code. It provides a short, direct path from design to execution.
Key factors that support young beginners:
  • Direct physical logic: Circuits function clearly based on physical connections, providing immediate visual feedback.
  • Instant visual feedback: Code updates upload quickly, making troubleshooting straightforward.
  • Integrated learning: Programming and circuit design are taught together, introducing core concepts like voltage and resistance through direct experimentation.
  • No prerequisites: Guided educational projects walk beginners through setup steps without requiring prior coding or electronics experience.
  • Broad community resources: Extensive documentation, tutorials, and wiring diagrams are readily available for beginner projects.
For a streamlined start, guided kits eliminate the need to source individual parts. Built around the NULA Mini ESP32-C6, the Embedded Journey Kit uses plug-and-play components to help kids construct projects quickly.
€34,95
Beginner kit
€34,95
Progress down the list sequentially. Each project builds directly on the previous build's concepts, utilizing visual or auditory outputs.
1. Blink your first LED
The standard introductory project. A basic script toggles a pin high and low, flashing the board's built-in LED. This teaches digital output configuration and how delay() controls timing intervals.
5mm LED Diode Pack (13 Pieces)
€1,50
€1,50
2. Build a traffic light
Three LEDs (red, yellow, green) cycle in a timed sequence. This transitions timing concepts from single delays into execution sequences. The traffic light simulator is included as a guided build in the Embedded Journey Kit.
3. Create a reaction time game
A two-player game using one LED and two pushbuttons. The LED illuminates at a random interval, and the first player to press their button wins. This project introduces digital input handling.
4. Electronic dice
Pressing a button triggers a random number calculation, displaying the result across an LED pattern. This builds directly on pushbutton logic and random number generation.
5. Smart night light
A photoresistor measures ambient light levels, switching on an LED when ambient light drops below a defined threshold. The Embedded Journey Kit provides photoresistors, a buzzer, LEDs, resistors, jumper wires, and a mini breadboard for this project.
6. Temperature monitor
Reads room temperature and outputs the values to a display. The DS18B20 digital sensor allows waterproof temperature sensing across multiple points over a single-wire interface.
€5,50
€5,50
7. Motion alarm
Triggers a buzzer sound and LED flash upon detecting movement. The alert components are supplied in the Journey Kit.
A passive infrared (PIR) sensor monitors motion by measuring changes in ambient infrared radiation. The sensor covers a range of 3 to 5 meters across a 100-degree field of view, connecting via plug-and-play Qwiic connectors without requiring soldering.
PIR Movement Sensor Board With Qwiic
Regular price  €5,95 Sale price  €3,95
8. Mini weather station
Displays temperature and humidity data on an LCD screen. The Journey Kit includes a 16x2 LCD, an ultrasonic distance sensor, and an SHTC3 temperature/humidity sensor, using solderless Qwiic cables for assembly.
9. Parking assistant
An ultrasonic sensor measures object distance, adjusting an LED output sequence as target proximity changes. The HC-SR04 measures distances between 2 cm and 400 cm using 5V operating logic.
Ultrasonic Module HC-SR04
€3,95
€3,95
10. Plant watering reminder
Monitors moisture levels and sounds an alert when soil conditions dry out. A capacitive soil moisture sensor measures moisture levels without exposed metal contacts, preventing electrode oxidation and avoiding current flow directly through the soil.
Capacitive Soil Sensor
€4,95
€4,95
11. Digital stopwatch
Uses pushbuttons to control a start, stop, and reset timer printed on a display. The 16x2 LCD from the Journey Kit handles the visual readout.
12. Simple electronic piano
Pushbuttons act as keys, sending specific pitch frequencies to a piezo buzzer. This project is included as a guided project in the Journey Kit.
13. Mood lamp
Controls an RGB LED using pulse-width modulation (PWM) to fade smoothly between color channels. The 13-piece 5mm LED diode pack includes RGB components designed for multi-color testing.
14. Home security alarm
Connects a door switch input to a buzzer output, serving as a practical exercise in conditional logic and state tracking.
15. Mini robot controller
Drives two DC motors to manage speed, direction, and turning logic. A dual H-bridge motor driver (such as the DRV8424P breakout) bridges the control board and motors, featuring built-in thermal shutdown, overcurrent protection, and undervoltage lockout.
Dual Motor H-Bridge DRV8424P Driver Breakout
€9,50
€9,50
Beginner Arduino projects typically combine these five basic components. Learning them in sequence establishes a clear foundation for more complex builds:
  1. LEDs: Introduce visual digital outputs.
  2. Pushbuttons: Introduce digital inputs and user event handling.
  3. Piezo buzzers: Add auditory outputs for alerts and feedback.
  4. Resistors: Protect components and limit current flow within circuits.
  5. Sensors: Introduce analog and digital environment readings (light, temperature, and distance).
Recommended hardware additions include a 400-contact breadboard for solderless circuit assembly, a 400-piece resistor kit covering 20 standard values, and an LED diode pack for component replacements.
Breadboard
Breadboard
€3,95
€3,95
Resistor Kit 400
Resistor Kit 400
€7,50
€7,50
Three main board choices suit most beginner hardware setups:
Best overall
The NULA Core is a compact, ATmega328P development board featuring 22 I/O pins, full Arduino IDE support, USB-C connectivity, and breadboard compatibility. It is the hardware successor to the Dasduino CORE board.
NULA Core
NULA Core
€11,95
€11,95
Best for learning electronics
The Embedded Journey Kit bundles the development board, Qwiic modules, and breadboard components into a single package. It supports both Arduino IDE and MicroPython programming.
Best if you want Wi-Fi projects
The NULA Mini ESP32-C6 is a compact IoT development board with Wi-Fi 6, Bluetooth 5.3, and multi-protocol hardware support.
Sourcing hardware from multiple suppliers can create compatibility issues for beginners. Integrated kits ensure operating voltages and pinouts align correctly out of the box.
The Embedded Journey Kit includes the main board, Qwiic expansion modules, and breadboard hardware in one package. Solderless Qwiic connectors allow rapid module connection.
For students interested in hardware assembly, the Make Your Own NULA Solder Kit provides hands-on soldering experience while constructing an ATmega328P microcontroller board.
  • Begin with basic LED output projects before moving to complex sensor setups.
  • Use complete starter kits to ensure component compatibility.
  • Treat minor component failures as standard troubleshooting practice.
  • Tailor project progression toward specific interest areas.
What is the best Arduino project for kids?
Blinking an LED is the ideal starting project. It confirms that the development board, USB cable connection, toolchain setup, and code compilation are functioning correctly.
What age can children start learning Arduino?
Basic guided projects can start around age 8 under adult supervision. Formal certification programs target older students, with Junior Certification recommended for ages 14+ and full certification aimed at ages 16+.
Are Arduino projects safe for kids?
Yes. These projects operate at low DC logic voltages (5V for NULA Core, 3.3V for NULA Mini ESP32-C6). Solderless breadboards and Qwiic modules allow full project construction without heat tools. Adult supervision is recommended if using soldering equipment.
What Arduino board is best for beginners?
The NULA Core is ideal for general development, offering 22 I/O pins, USB-C connectivity, and full Arduino IDE support. For IoT and wireless connectivity, the NULA Mini ESP32-C6 provides Wi-Fi 6 and Bluetooth 5.3.
Do kids need programming experience for Arduino?
No. Guided project kits step through code syntax from the ground up, assuming no prior programming experience.
What components should kids learn first?
Start with basic output and input components: LEDs, pushbuttons, buzzers, and current-limiting resistors. Next, transition to environmental sensors using a solderless breadboard.
Can Arduino be used in schools?
Yes. Arduino and compatible platforms like the Embedded Journey Kit are designed for classroom environments, STEM workshops, and structured self-study.
