Back to Blogs
15 e-paper display projects for makers and smart homes
31.08.2026
15 e-paper display projects for makers and smart homesE-paper vs LCD vs OLED displaysWhy Soldered Inkplate displays are ideal for e-paper projectsE paper display projects ideas: FAQs
Most displays are designed to be looked at for a moment, used, and then turned off.
E-paper displays are different.
They are built for information that should stay visible: a family calendar on the wall, a weather dashboard on your desk, a smart home status board by the door, or an energy monitor that quietly shows what is happening in your home throughout the day.
That is what makes e-paper so interesting for maker projects. It does not try to behave like a phone, tablet, or computer screen. Instead, it gives you something closer to digital paper: readable, low-power, and always available at a glance.
For Arduino, ESP32, Raspberry Pi, and smart home projects, this opens up a lot of creative possibilities. You can build displays that show sensor data, schedules, reminders, room status, air quality, power usage, or even simple artwork without needing a bright backlit screen running all day.
In this guide, we’ll explore practical e-paper display project ideas for makers, classrooms, workbenches, and smart homes, and show which type of display makes the most sense for each one.
Whether you want to build something useful for your home, classroom, desk, workshop, or smart home setup, e-paper gives you a very different kind of display experience. These projects are not about fast animations or constant interaction. They are about showing useful information clearly, quietly, and efficiently.
1. Family calendar display
A family calendar is one of the most practical e-paper display projects because it solves a real everyday problem. Instead of checking a phone or opening a shared calendar app, you can place a dedicated display in the kitchen, hallway, or entry area that shows the day’s events at a glance.
You can build it by connecting your calendar source to a microcontroller or Raspberry Pi, formatting the events into a clean daily or weekly layout, and refreshing the screen a few times per day. Since calendar information does not change every second, e-paper is a great fit.
A larger display works best here because you need room for dates, names, reminders, and time blocks.
€189,95 Price on 10.09.2026: 189,95 €
€189,95 - €219,95 Price on 10.09.2026: 189,95 – 219,95 €
For a bigger wall-mounted version with more visual space, you could also use:
Inkplate 13SPECTRA
Inkplate 13SPECTRA
€279,95 Price on 10.09.2026: 279,95 €
ESP32 Color e-Paper Board
€279,95 - €319,95 Price on 10.09.2026: 279,95 – 319,95 €
2. Weather dashboard
A weather dashboard is a classic e-paper project because weather data is useful, visual, and easy to understand. You can show the current temperature, forecast, humidity, wind, sunrise time, and simple weather icons.
A good first version could include:
  • Current temperature
  • Today’s high and low
  • Weather icon
  • Chance of rain
  • Indoor temperature from a local sensor
  • Last updated time
Once that works, you can make the display more personal by adding your city, preferred units, or a small “what to wear today” note.
For weather projects, color can make the display more readable and more fun, especially if you want icons, warnings, or different sections for indoor and outdoor conditions.
Inkplate 6COLOR
Inkplate 6COLOR
€169,95 Price on 10.09.2026: 169,95 €
€129,95 - €169,95 Price on 10.09.2026: 129,95 – 169,95 €
3. Smart home status board
A smart home status board gives you one place to check the state of your home. Instead of opening an app to see whether lights are on, doors are closed, windows are open, or sensors are active, you can show the most important information on a simple always-visible display.
A useful layout might include:
Front door: closed
Garage: open
Living room lights: off
Bedroom temperature: 22°C
Washing machine: running
Alarm: armed
The key is not to show everything. A good smart home display should only show the things you actually care about when walking past it.
For a central smart home status board, Inkplate 10 gives you enough room to group information by room or category.
4. Desk productivity dashboard
This project is ideal for a compact e-paper display on your desk. Instead of turning it into another distracting screen, use it for slow, useful information.
You could show:
  • Today’s top 3 tasks
  • Next meeting
  • Pomodoro timer status
  • Focus mode
  • Daily habit tracker
  • A short motivational note
A simple version can be updated manually or from a small script. A more advanced version could sync with a calendar, task manager, or local server.
For this kind of project, the display should be small enough to sit beside a keyboard or monitor without taking over the desk.
Inkplate 2
Inkplate 2
Regular price  €39,95 Sale price  €29,96 Lowest price in the last 30 days: 39,95 € Price on 10.09.2026: 39,95 €
€29,95 - €37,46 Price on 10.09.2026: 29,95 – 49,95 €
5. Energy monitoring display
Energy monitoring is one of the best use cases for e-paper because it gives you information you may want to check throughout the day, but not necessarily interact with constantly.
Start with a simple dashboard showing current consumption, today’s usage, and estimated cost. Later, you can add solar production, battery status, or historical comparisons.
One possible build path:
  1. Collect power data from a smart meter, sensor, or Home Assistant.
  2. Send the data to your microcontroller or Raspberry Pi.
  3. Create a simple layout with current usage and daily totals.
  4. Add small trend arrows or basic charts.
  5. Refresh the display every few minutes.
A larger e-paper display gives you enough space for numbers, labels, and charts without making the layout feel crowded.
6. Meeting room availability sign
This is a great office, school, or makerspace project. Mount an e-paper display outside a room and show whether the room is available, booked, or currently in use.
The display can show:
  • Room name
  • Current status
  • Next meeting
  • Start and end time
  • A simple “free until” message
Because room schedules change occasionally, not constantly, e-paper is a better fit than a bright screen that stays on all day.
For a compact room sign, a mid-sized display gives enough space for clear text without needing a large wall dashboard.
Inkplate 5Gen2
Inkplate 5Gen2
€99,95 Price on 10.09.2026: 99,95 €
€74,95 - €99,95 Price on 10.09.2026: 74,95 – 99,95 €
7. Smart mailbox notifier
A smart mailbox notifier is simple, useful, and surprisingly satisfying to build. The idea is to detect when the mailbox opens, then show the mailbox status somewhere inside the house.
A basic version could work like this:
  • A micro switch or sensor detects when the mailbox door opens.
  • A wireless board sends the event.
  • The display updates to show “Mail delivered.”
  • A timestamp shows when it happened.
  • A button or touch action resets the status.
This is a nice project because it combines a physical sensor with a visible result. For a small display near your desk or entrance, a compact Inkplate is enough.
Inkplate 4TEMPERA
Inkplate 4TEMPERA
Regular price  €119,95 Sale price  €89,96 Lowest price in the last 30 days: 119,95 € Price on 10.09.2026: 119,95 €
€89,96 - €159,95 Price on 10.09.2026: 119,95 – 159,95 €
8. Air quality monitor
An air quality dashboard can show indoor conditions in a way that is easy to understand at a glance. Instead of showing only raw numbers, you can turn the data into simple labels like “Good,” “Okay,” or “Ventilate room.”
You can include:
  • Temperature
  • Humidity
  • Air quality index
  • CO₂ or VOC level, depending on your sensor
  • A simple recommendation
  • Last updated time
Color e-paper works well here because you can use different colors to separate safe, warning, and action zones without making the dashboard feel busy.
Inkplate 6COLOR
Inkplate 6COLOR
9. Workshop status board
A workshop status board can show the kind of information you always need but never want to search for. This could be especially useful in a makerspace, garage, electronics lab, or classroom.
Ideas for what to display:
  • Current project notes
  • Tool checklist
  • Safety reminders
  • 3D printer status
  • Room temperature
  • Humidity
  • Next maintenance task
  • Parts to reorder
You could update it manually from a small web interface or automatically from sensors and devices around the room.
For a workshop display, you probably want something readable from a distance and large enough for multiple sections.
Inkplate 6
Inkplate 6
€109,95 Price on 10.09.2026: 109,95 €
€109,95 - €139,95 Price on 10.09.2026: 109,95 – 139,95 €
10. Plant care dashboard
A plant care dashboard turns sensor data into something easier to act on. Instead of checking soil moisture values in code, show a simple status display next to your plants.
A friendly version could show:
Basil: needs water
Monstera: okay
Humidity: 48%
Light: good
Last watered: Monday
To build it, start with one soil moisture sensor and one plant. Once the first version works, add more plants, rename each one, and show them as a small list.
For a compact plant shelf or windowsill display, a smaller e-paper module works well.
Inkplate 2
Inkplate 2
11. E-paper photo or art frame
An e-paper art frame is less about data and more about atmosphere. You can use it to show black-and-white artwork, generative patterns, family photos, quotes, or simple illustrations.
This is a good project when you want to experiment with:
  • Image conversion
  • Dithering
  • Layout design
  • Scheduled refreshes
  • Low-power wall displays
For color artwork, a color e-paper display is more interesting than a standard black-and-white panel. It will not behave like an LCD photo frame, but that paper-like look is exactly what makes it feel different.
Inkplate 13SPECTRA
Inkplate 13SPECTRA
12. Raspberry Pi server dashboard
If you run a Raspberry Pi as a home server, local dashboard, Home Assistant hub, Pi-hole, media server, or automation controller, an e-paper status screen can show the important details without needing to connect a monitor.
Useful values include:
  • CPU usage
  • Memory usage
  • Disk space
  • IP address
  • Service status
  • Uptime
  • Last backup
  • Temperature
This project is especially useful because the display can stay visible even when you are not logged into the Raspberry Pi.
For a simple local server dashboard, you can pair a Raspberry Pi with an Inkplate display or use the Inkplate as a dedicated status screen that receives data from the Pi.
Raspberry Pi 5, 4GB
Raspberry Pi 5, 4GB
€108,95 Price on 10.09.2026: 108,95 €
Inkplate 5Gen2
Inkplate 5Gen2
13. Motion-aware hallway display
A hallway display does not need to show everything all the time. It can stay quiet most of the day, then update or change content when someone walks past.
Possible information:
  • Time and date
  • Weather
  • Front door status
  • Reminder before leaving
  • Calendar event
  • “Take umbrella” warning
  • Package or mailbox notice
A motion-aware display is a nice bridge between passive e-paper and a more interactive smart home project. Instead of touching the screen or opening an app, the display reacts to presence.
Inkplate 6MOTION
Inkplate 6MOTION
€179,95 Price on 10.09.2026: 179,95 €
€179,95 - €209,95 Price on 10.09.2026: 179,95 – 209,95 €
14. Classroom information board
A classroom e-paper board can show useful information without becoming another bright, distracting screen. It can display the day’s schedule, homework reminder, classroom temperature, project instructions, or a question of the day.
A good classroom version should be simple:
  1. Choose one purpose first, such as daily schedule or homework.
  2. Design a large, readable layout.
  3. Update it once or twice per day.
  4. Add icons or sections only after the text version works.
For classrooms, a larger display is useful because students should be able to read it from a distance.
If you want a more visual version with color sections or subject labels, this could also work well with a color e-paper display.
Inkplate 6COLOR
Inkplate 6COLOR
15. Touchscreen smart control panel
Most e-paper projects are passive displays, but a touchscreen e-paper module lets you add simple interaction. This can be useful for a smart room controller, dashboard menu, counter reset button, or low-power control panel.
You could create screens for:
  • Room status
  • Lighting modes
  • Temperature
  • Energy usage
  • Calendar
  • Sensor data
The goal is not to build a tablet replacement. It is to create a calm, low-power interface for actions that do not need fast animations or constant scrolling.
Inkplate 6FLICK is a strong fit here because it combines e-paper with touch support and faster refresh behavior, making it better suited for interactive dashboard projects than a traditional slow-refresh e-paper screen.
Inkplate 6FLICK
Inkplate 6FLICK
€209,95 Price on 10.09.2026: 209,95 €
E-paper, LCD, and OLED displays can all work well in maker projects, but they are not built for the same kind of experience. The best choice depends on whether your project needs to stay visible all day, update quickly, show rich colors, or run on very little power.
Display type
Best for
Main advantage
Not ideal for
E-paper
Calendars, dashboards, signs, labels, sensor displays, smart home status boards
Very low power for static content and excellent readability
Video, fast animations, frequent scrolling
LCD
Menus, live data, simple interfaces, budget displays
Affordable, widely available, and good for frequently changing content
Always-on low-power displays
OLED
Compact displays, sharp text, icons, high-contrast interfaces
Excellent contrast and deep blacks
Larger always-on dashboards, long static content
For most e-paper projects, the key question is not whether the display is the most colorful or fastest. It is whether the information should remain visible without becoming distracting or power-hungry.
That is why e-paper is such a good fit for wall calendars, weather dashboards, room signs, energy monitors, and smart home status boards. These projects usually need clarity more than animation.
If your project needs a bright interactive screen with constant updates, LCD or OLED may be a better choice. But if you want a calm, readable display that can sit on a wall, desk, shelf, or workshop bench and quietly show useful information all day, e-paper is often the more natural choice.
E-paper projects work best when the display becomes part of everyday life.
A calendar in the hallway. A weather dashboard on your desk. A smart home status board near the door. A workshop display that shows project notes, sensor values, or reminders. These are not screens you constantly interact with. They are quiet, useful displays that stay visible when you need them.
That is exactly where Inkplate displays fit.
Instead of starting with a raw e-paper panel and figuring out the controller, power management, enclosure, and development setup separately, Inkplate gives makers a more complete platform for building real projects. You can start with a simple dashboard, then expand it with sensors, wireless data, touch interaction, color, motion, or a larger screen as the project grows.
Soldered also offers different Inkplate options for different project types. A compact display like Inkplate 2 works well for desk widgets and small status screens. Inkplate 6FLICK is a better fit when you want touch interaction or a more responsive dashboard. Inkplate 6COLOR and Inkplate 13SPECTRA are useful when color helps separate information visually. For larger home, classroom, or workshop dashboards, Inkplate 10 gives you more room to show calendars, weather, energy data, and smart home status in one clean layout.
The best e-paper project is not always the most complicated one. It is the one that shows useful information clearly and makes it easier to understand what is happening around you.
With Inkplate displays, Soldered gives makers a practical way to build those projects without turning every idea into a complex display-integration problem.
What is an e-paper display?
An e-paper display is a screen designed to look more like printed paper than a traditional glowing display. It is commonly used for calendars, dashboards, signs, labels, e-readers, and low-power information screens where content should stay visible for a long time.
How does an e-paper display work?
An e-paper display works by moving tiny charged particles inside the screen to create visible text and images. Once the image is shown, it can remain visible without the display constantly refreshing like an LCD or OLED screen.
What are e-paper displays good for?
E-paper displays are best for projects that show mostly static or slowly changing information. Good examples include weather dashboards, family calendars, smart home status boards, meeting room signs, energy monitors, classroom boards, workshop displays, and sensor dashboards.
Are e-paper displays good for Arduino and ESP32 projects?
Yes. E-paper displays are great for Arduino and ESP32 projects, especially when you want to show sensor data, status messages, weather information, counters, reminders, or dashboard information without using a bright always-on screen.
Can you use an e-paper display with Raspberry Pi?
Yes. Raspberry Pi can be used with e-paper displays for dashboards, home servers, calendar displays, weather stations, monitoring systems, and smart home projects. Raspberry Pi is especially useful when the project needs APIs, local scripts, databases, or more processing power.
What is the difference between e-paper and LCD?
The main difference is how the display behaves. LCD screens are better for frequently changing content, menus, and live interfaces. E-paper is better for information that should stay visible for a long time while using very little power, such as calendars, labels, dashboards, and signs.
What is the difference between e-paper and OLED?
OLED displays are bright, high-contrast screens that work well for compact interfaces, icons, and fast updates. E-paper displays are slower, but they are easier to read for long periods and are much better suited for low-power always-visible information screens.
Can e-paper displays show color?
Yes, some e-paper displays can show color. Color e-paper is useful for weather icons, charts, air quality indicators, calendars, signage, labels, and dashboards where color helps separate information visually. It is not the same as an LCD screen, but it can make static information much easier to scan.
Are e-paper displays good for smart home dashboards?
Yes. E-paper displays are a strong fit for smart home dashboards because many smart home values do not need to update every second. They work well for showing room temperatures, door status, lighting status, energy usage, weather, alarms, and calendar information.
