LCD display guide: types, how they work, and Arduino project ideas
20.10.2026
What is an LCD display?How does an LCD display work?Common types of LCD displaysLCD vs OLED vs LED matrix vs e-paperWhen should you use an LCD display?When should you choose e-paper instead of LCD?How to use an LCD display with ArduinoHow to use an LCD display with ESP32LCD display project ideasCommon mistakes when using LCD displaysHow to choose the right display for your projectWhy Soldered is a great place to start building display projectsFrequently asked questions
An LCD is the first screen most makers use. It is cheap, it shows text and numbers, and an I2C version connects to an Arduino or ESP32 with one cable. This guide covers how LCDs work, which types exist, how to wire one up, and when e-paper is the better choice.
LCD stands for liquid crystal display. The liquid crystals do not make light. They block or pass light from a backlight behind them.
Calculators, thermostats and multimeters all use them. For makers, the usual one is the 16x2 character LCD: 16 characters on each of 2 rows. Soldered's version has an I2C adapter already fitted and a Qwiic connector.
LCD Display I2C White/Blue
€13,95
€13,95
Each pixel is a tiny window of liquid crystal. A voltage turns the crystals, and that decides whether backlight gets through. A controller chip, usually the HD44780, handles the pixels, so your code only sends characters and commands.
  1. The microcontroller sends a character or a command.
  2. The LCD controller decides which pixels to change.
  3. The liquid crystals in those pixels turn.
  4. The backlight shows through the open pixels.
Character LCD displays
A character LCD shows letters and digits in a fixed grid, each in its own 5x8 dot box. The usual sizes are 16x2 and 20x4. Use one for values, menus and status messages. It is the most common display in Arduino beginner projects.
Graphic LCD displays
A graphic LCD is a grid of individual pixels, for example 128x64. It can draw icons, shapes and fonts of any size. It is more flexible than a character LCD, but harder to program.
TFT LCD displays
A TFT LCD is a full-colour screen. It suits touch interfaces, charts and dashboards. It needs more memory than a character LCD, and the backlight draws more power.
I2C LCD displays
A bare character LCD has 16 pins and needs six or more of your board's pins. An I2C LCD adds a small adapter on the back, so you need only four wires: VCC, GND, SDA and SCL. With Qwiic, those four are one cable.
Back of a 16x2 LCD with the Soldered I2C LCD adapter board and its Qwiic connector
The adapter turns sixteen parallel pins into one Qwiic cable
Our I2C protocol guide explains how several devices share those two signal wires.
Display type Best for Not ideal for
LCD Menus, live values, sensor readings Low-power, always-on dashboards
OLED Sharp compact screens, icons, high contrast Large static displays
LED matrix Scrolling text, animations, scoreboards Detailed text
E-paper Dashboards, calendars, weather displays Video and fast animation
An LCD suits values that change often. E-paper suits information that stays on screen for hours, because it uses power only while the image changes. Inkplate 6FLICK is an e-paper display with an ESP32 and a touchscreen built in.
Inkplate 6FLICK
Inkplate 6FLICK
€179,95
€179,95 - €209,95
For scrolling text and animation, see our LED matrix projects.
Use an LCD when the project shows a small amount of information that changes often:
  • sensor readings
  • short text messages
  • menus and device settings
  • timers and counters
  • classroom and budget Arduino projects
If it fits in 32 characters and the project is plugged in, a 16x2 LCD is usually the simplest display that works.
Choose e-paper when the screen shows the same thing most of the time and has to stay readable all day. It holds the image with no power, reads like paper in daylight and fits a full page layout instead of 32 characters.
That makes Inkplate the better fit for weather dashboards, family calendars, room signs, smart home dashboards, energy monitors and workshop status displays. For a small label or a single value, Inkplate 2 is a compact three-colour e-paper display with an ESP32 on board.
Inkplate 2
Inkplate 2
Regular price  €39,95 Sale price  €29,96
€29,95 - €37,46
Our e-paper display guide explains how the technology works.
Connect four pins, or plug in a Qwiic cable if your board has the connector.
LCD pin Arduino pin
VCC 5V
GND GND
SDA SDA (A4 on an ATmega328 board)
SCL SCL (A5 on an ATmega328 board)
In the Arduino IDE, open Sketch > Include Library > Manage Libraries, search for Soldered LCD and install it. Generic LiquidCrystal_I2C libraries do not work with Soldered's adapter.
 * Print two lines of text on a Soldered 16x2 I2C LCD.
 * Connection: Qwiic cable, or VCC, GND, SDA and SCL
 * Board:      any Arduino-compatible or ESP32 board
 * Library:    "Soldered LCD", from the Arduino Library Manager
#include "LCD-SOLDERED.h"
// The display: 16 columns, 2 rows
LCD lcd(16, 2);
  // Start the display and switch the backlight on
  lcd.begin();
  lcd.backlight();
  lcd.clear();
  // Column 0, row 0 is the top-left corner
  lcd.setCursor(0, 0);
  lcd.print("Hello, world!");
  // Row 1 is the bottom line, 16 characters wide
  lcd.setCursor(0, 1);
  lcd.print("LCD is working");
If the backlight is on but the screen looks empty, turn the contrast potentiometer on the back of the adapter.
Want to build the board too? The Make your own NULA kit has you solder an Arduino-compatible board from parts, and the sketch above runs on it.
Make Your Own NULA Solder Kit
An ESP32 adds Wi-Fi and Bluetooth, so the LCD can show MQTT messages, Home Assistant values or data from a web API. The same sketch runs unchanged. Check two things:
  • Voltage. ESP32 pins run at 3.3 V. Soldered's adapter accepts 3.3 V logic. A 5 V-only module may not.
  • I2C pins. They differ between ESP32 boards. Check your pinout, or use Qwiic.
NULA Mini ESP32-C6 has Wi-Fi 6, Bluetooth and a Qwiic connector, so it plugs straight into the LCD.
Temperature and humidity display
Read a sensor every few seconds and print both values, one per line. It is a good first project because two I2C devices share one bus.
16x2 LCD showing 27.9 °C and 40.8 % humidity from an SHTC3 sensor connected over Qwiic
Sensor and LCD daisy-chained on one Qwiic bus
Digital clock
An RTC (real-time clock) module keeps time on its own backup battery. Print the time every second. Add a button and a buzzer for an alarm.
Real Time Clock RTC PCF85063A Breakout
€3,95
€3,95
Distance display
An ultrasonic sensor times a sound pulse to measure distance. Print it and you have a parking sensor or a tank level meter. The HC-SR04 is a 5 V part, so check the echo pin's voltage before you connect it to an ESP32.
Ultrasonic Module HC-SR04
€3,95
€3,95
Plant monitor
Show soil moisture and print "Water me" when it drops below a threshold.
Capacitive Soil Sensor
€4,95
€4,95
Door or window status display
A reed switch tells the board whether a door or window is open. Show each one on the LCD, so you can check the house before you leave.
Menu system
Buttons for up, down and select turn the LCD into a settings screen for any project. The Zero to Hero kit includes the LCD, buttons and a NULA board, and its examples build up to a Wi-Fi alarm clock.
€34,95
Beginner kit
€34,95
Energy monitor
Print voltage on one line and current on the other. Multiply them for power.
€7,50
€7,50
For a graph of the whole day, a 9.7-inch Inkplate 10 is the better screen.
€189,95
€189,95 - €219,95
Home Assistant status display
An ESP32 can show the indoor temperature, the alarm state or whether the garage door is closed. For a full dashboard, see our guide to Home Assistant e-paper displays.
Classroom counter or timer
An LCD and two buttons make a quiz scoreboard or a countdown timer for group work. A class of beginners can finish it in one lesson.
E-paper weather dashboard
This is the next step when a project outgrows 32 characters. The ESP32 downloads the forecast every half hour and draws it with icons. Between updates, the screen uses no power.
Inkplate 6COLOR
Inkplate 6COLOR
€169,95
€129,95 - €169,95
  • Wrong I2C address. Many tutorials use 0x27. Soldered's adapter defaults to 0x20.
  • Contrast not set. Backlight on, screen empty. Turn the potentiometer on the back.
  • SDA and SCL swapped. Nothing shows and nothing reports an error.
  • Wrong library. Generic libraries compile but do not drive the adapter.
  • Too much text. Each line fits 16 characters. The rest is cut off.
  • LCD on a battery. The backlight drains it. Use e-paper instead.
Project goal Best display choice
Show simple text and values LCD
Show menus on an Arduino project LCD
Build a compact high-contrast interface OLED
Create scrolling text or animations LED matrix
Create a colourful touch interface TFT LCD
Build a weather dashboard Inkplate / e-paper
Build a smart home status board Inkplate / e-paper
Build a low-power wall display Inkplate / e-paper
Display data from a Raspberry Pi LCD for a few values, e-paper for a dashboard, HDMI for a desktop
Soldered makes the parts for both ends of this guide. Start with a 16x2 I2C LCD, a NULA board and a Qwiic sensor, with no soldering. When the project needs more space or has to run all day, the same ESP32 code moves to an Inkplate.
A screen that uses liquid crystals to control how light from a backlight passes through it. In projects, it shows text, numbers, menus and sensor values.
A voltage turns the liquid crystals in each pixel, which decides whether the backlight gets through.
What is a 16x2 LCD display?
A character display that shows 16 characters on each of 2 rows. It is the most common display in Arduino beginner projects.
What is an I2C LCD display?
An LCD with an adapter that talks over I2C. It needs four connections, VCC, GND, SDA and SCL, instead of sixteen.
Can I use an LCD display with Arduino?
Yes. LCDs work with any Arduino-compatible board, for sensor readings, menus, timers and counters.
Can I use an LCD display with ESP32?
Yes. Use one that accepts 3.3 V logic. Choose an ESP32 when the display needs Wi-Fi, MQTT or Home Assistant data.
What is the difference between LCD and OLED?
An LCD blocks light from a backlight. An OLED pixel makes its own light, which gives higher contrast and true black.
What is the difference between LCD and e-paper?
An LCD suits values that change often. E-paper suits information that stays on screen all day, because it holds the image with no power.
Should I use LCD or Inkplate for my project?
An LCD for a few live values, menus or frequent updates. Inkplate for a larger, low-power display that shows dashboards, calendars or weather all day.
What projects can I build with an LCD display?
Temperature displays, clocks, distance readouts, plant monitors, menus, energy monitors, classroom timers and smart home status screens.
Why is my LCD display not showing text?
Check the contrast potentiometer first. After that, the I2C address, the SDA and SCL wiring, and the library.
Is LCD better than LED matrix?
For readable text and menus, yes. An LED matrix is better for scrolling text, animation and anything seen across a room.
