Back to Blogs
20 STEM projects for kids that teach electronics, coding, and problem solving
25.08.2026
20 STEM projects kids can build (sometimes with adult help)STEM projects by ageWhy Soldered is a great place to start building STEM projectsSTEM projects for kids: FAQs
STEM projects don't have to be complicated, expensive, or require years of programming experience.
In fact, some of the best projects start with a single LED, a simple sensor, or a few lines of code that make something happen for the very first time.
If you're a parent looking for a fun weekend activity, a teacher searching for hands-on classroom ideas, or a young maker curious about how technology works, building real electronics is one of the best ways to learn.
Instead of simply reading about science and engineering, you'll be experimenting, solving problems, and creating projects you can actually see and interact with.
In this guide, we've listed 20 beginner-friendly STEM projects that introduce coding, electronics, robotics, and IoT in a fun and approachable way with our products that can help you out in your build.
Let’s dive right in.
The best STEM projects are the ones kids can understand, finish, and proudly show to someone afterward. These ideas start simple, but many of them can grow into bigger projects as confidence builds.
Some are perfect for a first afternoon with electronics. Others are better for older kids, classrooms, STEM clubs, or parent-child weekend projects.
1. Build your first traffic light
A traffic light is a perfect first electronics project because kids already understand how it works in real life. The project starts with three LEDs: red, yellow, and green. From there, children write a simple program that turns each LED on and off in the right order.
It may look simple, but this project teaches several important ideas at once: digital outputs, timing, sequencing, and basic logic. Once the first version works, kids can make it more realistic by changing the timing or adding a pedestrian button.
If you're starting from zero, a guided electronics kit is the easiest way to avoid the usual beginner frustration of missing parts or incompatible components.
€34,95
Beginner kit
€34,95
2. Create a digital dice
This is a small project, but kids usually love it because it feels like a real gadget.
The idea is simple: press a button and display a random number from 1 to 6. Depending on the setup, the number can appear on LEDs, a small display, or even as a pattern that looks like a real dice face.
Along the way, children learn how buttons work, how random numbers are generated in code, and how electronics can react to user input.
A beginner-friendly Arduino-compatible board is a great foundation for this kind of project because it keeps the focus on learning the logic rather than fighting with the hardware.
Product title
Product title
€19,99
3. Build a weather station
A weather station is one of those projects that feels useful almost immediately.
Start by measuring temperature, then add humidity, pressure, or outdoor readings later. Kids can record the data every day, compare it with the forecast, and start noticing patterns in the environment around them.
This project combines electronics, coding, and science in a very natural way. It also teaches that data is more interesting when you collect it yourself.
A waterproof temperature sensor makes it easier to experiment both indoors and outdoors.
€5,50
€5,50
4. Create a smart plant monitor
Plants are great for STEM projects because they give kids something real to care for.
Instead of guessing when a plant needs water, children can use a soil moisture sensor to measure how dry the soil is. The project can start with a simple LED that turns on when the plant needs watering. Later, it can become a full dashboard or notification system.
What makes this project especially nice is that it connects electronics with biology. Kids learn that sensors are not just abstract components. They can help us understand living things.
Capacitive Soil Sensor
€4,95
€4,95
5. Make a mini OLED pet
This project is part coding, part creativity.
Kids can create a small digital pet that shows different moods on an OLED display. It can smile when a button is pressed, look sleepy after a while, or react when a sensor detects movement or light.
The first version can be very simple: just a few faces on a screen. But once children understand how it works, they can add personality, animations, sounds, and rules.
A small OLED display is perfect for this because it gives the project a real interface without making the build too complicated.
€9,95
€9,95
6. Build an electronic piano
Music makes electronics feel instantly rewarding.
Instead of waiting for a hidden sensor value or debugging a silent circuit, kids press a button and immediately hear a sound. That quick feedback makes this project especially fun for younger makers.
A simple electronic piano teaches how buttons trigger actions, how sound can be generated with code, and how different inputs can produce different outputs. Once the basic version works, children can try changing notes, creating melodies, or turning it into a small sound effects machine.
If you want a project that also introduces soldering in a structured way, a piano soldering kit is a strong starting point.
Piano Solder Kit
Piano Solder Kit
€15,95
€15,95
7. Make a motion detector alarm
This is the kind of project kids immediately understand because it feels like something from a spy movie.
Use a motion sensor to detect movement, then trigger an LED, buzzer, or warning message. It can become a bedroom door alarm, a toy box guard, or a simple security system for a classroom demonstration.
The project teaches input and output in a very clear way: the sensor detects something, the board makes a decision, and the alarm responds.
For beginners, start with a buzzer or LED. For older kids, add logging, wireless notifications, or a small display.
PIR Movement Sensor Board
€6,95
€6,95
8. Build a garage parking assistant
This project introduces distance measurement in a way that feels practical.
Using an ultrasonic sensor, kids can measure how far an object is from the sensor. Put it near a wall, toy car, or cardboard garage and the project becomes a mini parking assistant.
A simple version can use LEDs:
  • Green means far away
  • Yellow means getting close
  • Red means stop
That makes the concept easy to understand visually. It also teaches how sensors can help machines understand the physical world.
Ultrasonic Module HC-SR04
€3,95
€3,95
9. Create a classroom counter
Counting people, button presses, or objects is a great way to introduce data and logic.
A classroom counter can start with a single button that increases a number every time someone presses it. Then kids can add a second button to subtract, a display to show the count, or sensors that detect movement automatically.
This project is useful for learning variables, conditions, and simple math in code. It can also become a fun classroom tool for voting, attendance, or tracking team points.
A small display makes the project feel more complete because children can instantly see the result of their code.
€9,95
€9,95
10. Build a digital thermometer
A digital thermometer is simple, useful, and easy to expand.
Start by reading temperature from a sensor and printing the value on a screen. Then add thresholds, such as showing a warning when the room becomes too warm or too cold.
This project is a great bridge between electronics and everyday science. Kids learn that a sensor is not magic. It measures something real, sends data to the board, and the program decides what to do with that information.
€5,50
€5,50
11. Create a smart bird feeder
This is a lovely project for kids who enjoy nature.
Start with a simple bird feeder and add a sensor that detects when something visits. The first version can count visits or turn on an LED. Later, older students can add a camera, timestamp events, or compare activity at different times of day.
The project connects biology, engineering, and data collection. It also encourages observation, which is one of the most important parts of science.
If the project grows into image recognition, a Raspberry Pi setup can take it much further.
Raspberry Pi 5, 4GB
Raspberry Pi 5, 4GB
€108,95
€108,95
12. Build a reaction timer game
Reaction timer games are fun because they turn learning into competition.
The project works like this: an LED turns on after a random delay, and the player has to press a button as quickly as possible. The device then calculates the reaction time.
Kids learn about timing, randomness, buttons, and simple game logic. They also get to test the project repeatedly, which makes debugging feel more like playing than working.
A beginner electronics kit works well here because the project needs only a few basic parts, but teaches a lot.
€34,95
Beginner kit
€34,95
13. Create a weather dashboard
Once kids have built a basic weather station, the next step is making the data easy to read.
A weather dashboard can show temperature, humidity, forecast notes, or even a simple weather icon. Instead of checking an app, children build their own display that updates automatically.
This is where e-paper becomes especially interesting. Weather data does not need to refresh every second, so an e-paper display can stay visible all day while using very little power.
Inkplate 6FLICK
Inkplate 6FLICK
€179,95
€179,95 - €209,95
14. Make an e-paper classroom notice board
This is a great project for schools, clubs, or a desk at home.
Students can build a digital notice board that shows useful information, such as:
  • Today's schedule
  • Homework reminders
  • Classroom temperature
  • A quote of the day
  • Upcoming events
The fun part is that it feels like a real product. Kids are not just blinking an LED; they are creating something people can actually use.
Because e-paper is readable and low power, it works especially well for information that changes a few times per day.
€189,95
€189,95 - €219,95
15. Build a smart calendar display
A smart calendar display is a nice step up from simple sensor projects.
Kids can start with a basic date and time display, then add events, reminders, or icons for school activities. It introduces scheduling, time, data formatting, and user-friendly design.
This project is also a good way to teach that engineering is not only about making something work. It is also about making information easy to understand.
A larger e-paper display gives the project enough space to feel like a proper family or classroom dashboard.
€189,95
€189,95 - €219,95
16. Build your own Home Assistant sensor
This one is best for older kids or teenagers who are ready for connected projects.
The idea is to build a sensor that sends data to a smart home platform. It could report temperature, humidity, motion, or whether a door is open. Once connected, the sensor can trigger automations, alerts, or dashboards.
This project introduces IoT in a practical way. Kids learn that devices can communicate with each other, share data, and become part of a larger system.
For Wi-Fi projects, an ESP32-based board is a natural choice.
17. Create a wildlife observation station
This project starts with a simple question: what visits the garden when nobody is watching?
A basic version can use a motion sensor to detect activity near a bird feeder, balcony, or garden area. Kids can record the time of each visit and compare activity during the day.
For older students, this can grow into a camera-based project that captures images and uses AI to identify birds or animals. That makes it a great introduction to computer vision without starting with something too abstract.
Raspberry Pi AI Camera
Regular price  €99,95 Sale price  €59,95
18. Build a robot brain
A robot does not need to be complicated to teach important STEM ideas.
Start with a board that reads sensors and controls outputs. Add distance sensing, lights, buttons, or motors later. The goal is to help kids understand how a robot makes decisions: it senses something, processes information, and reacts.
This project is a great introduction to robotics, control systems, and problem solving. It also gives plenty of room to experiment because every new sensor changes what the robot can do.
NULA Max RP2350
NULA Max RP2350
€24,95
€24,95
19. Design an AI recycling sorter
This is a more advanced project, but it connects technology with a real-world problem.
Students can build a system that uses a camera to recognize different objects and classify them into categories such as plastic, paper, metal, or general waste. Even if the first version is simple, it opens a conversation about sustainability, AI, and how machines learn from images.
This project is especially good for older kids, STEM clubs, or classroom demonstrations where the goal is to show how artificial intelligence can be used in everyday life.
20. Build a smart classroom dashboard
This is the kind of final project that brings everything together.
A smart classroom dashboard can display temperature, humidity, air quality, reminders, schedules, or even data collected from other student projects. It combines sensors, programming, data visualization, and design thinking.
The best part is that the dashboard can keep growing. One group of students can add weather data, another can add a calendar, and another can connect classroom sensors.
For a polished always-on display, a large e-paper screen is a great fit.
€189,95
€189,95 - €219,95
Not every STEM project needs to be advanced to be useful. Younger kids usually benefit most from projects that give instant feedback, like lights, sounds, and simple games. Older kids can gradually move into sensors, dashboards, IoT, robotics, and AI.
Ages 6-8
At this age, the goal is not to teach complex coding. It is to help kids understand that electronics can respond to their actions. Projects should be short, visual, and fun.
Good projects for this age group include:
  • Electronic piano- Kids press buttons and immediately hear sound, which makes cause and effect easy to understand
  • Digital dice - A fun introduction to buttons, randomness, and simple logic
  • Traffic light - A great first project for learning LEDs, timing, and sequences
These projects work best with adult help, especially for wiring, soldering, or uploading code.
Ages 9-12
This is a great age for introducing sensors and real-world problem solving. Kids can start asking questions like, “How dry is the soil?”, “How far away is the object?”, or “What is the temperature right now?”
  • Weather station - Teaches temperature, humidity, data collection, and observation
  • Smart plant monitor - Combines electronics with biology and environmental science
  • Parking sensor - Introduces distance measurement and practical automation
These projects are still beginner-friendly, but they feel more useful because they measure something from the real world.
Ages 13-16
Older kids and teenagers can take on projects that involve connected devices, dashboards, automation, and even AI. At this stage, projects can become more open-ended and closer to real engineering work.
  • Home Assistant sensor - Introduces IoT, smart home automation, and wireless communication
  • AI camera project - A strong introduction to computer vision and machine learning
  • Inkplate dashboard - Great for learning displays, APIs, data formatting, and low-power design
  • Raspberry Pi project- Best for more advanced work involving Linux, coding, local servers, or AI
These projects usually require more patience and troubleshooting, but they also give teenagers much more room to customize and experiment.
Project
Recommended age
Difficulty
Notes
7–10
Beginner
Great first LED and timing project
8–11
Beginner
Good intro to buttons and random numbers
9–13
Beginner/intermediate
Combines sensors, data and observation
9–13
Nice mix of electronics and biology
9–13
Intermediate
Creative coding + display project
8–12
Beginner
Fun because kids hear instant feedback
9–13
Works well as a “spy gadget” project
10–14
Intermediate
Teaches distance sensing in a practical way
8–12
Beginner
Good for buttons, counting and displays
8–12
Beginner
Simple sensor project with real-world value
10–14
Intermediate
Combines nature, sensors and observation
8–12
Beginner
Competitive and fun for classrooms
11–15
Intermediate
Good next step after weather station
11–15
Intermediate
Great classroom/group project
12–16
Intermediate
Adds scheduling, UI and data formatting
13–16+
Advanced
Better for teens already comfortable with tech
12–16+
Intermediate/advanced
Can grow into AI/computer vision
Build a robot brain
12–16+
Good intro to robotics and decision-making
14–16+
Advanced
Best for STEM clubs or guided classrooms
13–16+
Advanced
Strong final/group project
Note: Age ranges are only a rough guide. Younger children can complete many of these projects with adult help, while older kids can make them more advanced by adding sensors, displays, Wi-Fi, or automation.
STEM learning works best when kids can turn an idea into something real.
A blinking LED, a tiny electronic piano, a plant monitor, or a classroom dashboard may seem simple at first, but each project teaches an important lesson: how to experiment, solve problems, and understand the technology behind everyday devices.
That is where Soldered can help. Instead of starting with random components that may or may not work together, beginners can choose development boards, sensors, displays, and kits designed for hands-on learning. From the Embedded Journey Kit and Dasduino boards to ESP32-based projects, Raspberry Pi hardware, and Inkplate e-paper displays, Soldered gives young makers a clear path from their first circuit to more advanced STEM builds.
The best part is that these projects can grow with them. A traffic light can become a smart crossing system. A weather station can become an always-on Inkplate dashboard. A simple sensor project can later connect to Home Assistant, Raspberry Pi, or even AI-powered applications.
Whether you are a parent planning a weekend activity, a teacher preparing a classroom project, or a student curious about electronics, Soldered provides the tools, documentation, and support to make STEM learning practical, creative, and fun.
What are the best STEM projects for kids?
The best STEM projects for kids are hands-on activities that teach science, technology, engineering, and math through building. Great examples include traffic lights, digital dice, weather stations, plant monitors, reaction timer games, electronic pianos, parking sensors, and simple robotics projects.
What are easy STEM projects for kids?
Easy STEM projects for kids usually involve simple circuits, LEDs, buttons, sensors, or displays. Projects like a blinking LED, traffic light, digital thermometer, electronic dice, or reaction timer are great starting points because kids can quickly see how their code affects the real world.
What age is best for STEM projects?
Children can start simple STEM projects around ages 6–8 with adult help. Younger kids usually enjoy visual and interactive projects like lights, sounds, and games, while older kids can build more advanced projects involving sensors, dashboards, robotics, IoT, and AI.
Are STEM projects safe for kids?
Yes, STEM projects are safe for kids when they use low-voltage electronics, beginner-friendly kits, and adult supervision where needed. Projects using LEDs, sensors, Arduino-compatible boards, and small displays are generally safe for learning, as long as children avoid mains electricity and use tools responsibly.
What do kids learn from STEM projects?
STEM projects help kids learn problem-solving, creativity, coding, electronics, logical thinking, measurement, and experimentation. They also teach children how to turn an idea into something real, test it, improve it, and understand why it works.
What are good STEM projects for 10-year-old kids?
Good STEM projects for10year-old kids include weather stations, smart plant monitors, parking sensors, motion alarms, digital thermometers, and classroom counters. These projects are still approachable but introduce real-world sensors, data collection, and simple automation.
Can kids learn codig through STEM projects?
Yes. STEM projects are one of the best ways for kids to learn coding because they make programming visible and interactive. Instead of only writing code on a screen, children can use code to turn on LEDs, read sensors, play sounds, display data, or control a small device.
What is the best STEM kit for beginners?
The best STEM kit for beginners is one that includes a development board, basic components, sensors, instructions, and project examples. A complete kit helps kids avoid the frustration of buying random parts that may not work together and lets them focus on learning by building.
