Seeed Studio is one of the best known names in maker electronics. Grove modules, XIAO boards, sensors, edge AI hardware, Raspberry Pi accessories, industrial IoT devices: the catalog covers almost everything.
That breadth is the appeal. It is also the reason people look elsewhere. If you already know what you are building, thousands of near-identical modules is more work, not less.
This guide compares six Seeed Studio alternatives and says which one fits which kind of project.
Why people choose Seeed Studio in the first place
Seeed Studio gives makers a very large toolbox. If you want sensors, XIAO boards, Grove modules, edge AI devices, Raspberry Pi add-ons or industrial IoT hardware, there is a good chance something in the catalog fits. For many builders that variety is the whole reason to start there.
What Seeed Studio does well:
- One of the largest catalogs in maker electronics
- Grove, a plug-and-play module ecosystem with hundreds of parts
- XIAO, a family of very small development boards
- Edge AI and industrial IoT hardware, including reComputer systems and Jetson Orin boards
- A wide sensor and module range for prototyping
- Documentation and an active community
If your work involves trying many different ideas quickly, that catalog is hard to beat.
When a Seeed Studio alternative makes more sense
A bigger catalog is not automatically better. If your goal is a low-power display, a smart home dashboard, a classroom electronics project or a beginner soldering kit, a more focused range saves time. Instead of comparing a dozen similar modules, you start with hardware built around a finished project.
An alternative is usually the better call when you want:
- A focused e-paper platform instead of raw display panels
- An all-in-one display board with the controller, power management and enclosure already sorted
- Beginner-friendly solder kits that end in something that works
- EU-made or EU-stocked maker hardware
- A curated selection of boards and displays rather than a marketplace
- A clear path from a first LED to a real project
- Project-based documentation and support from the people who designed the board
Best Seeed Studio alternatives
1. Soldered: best for e-paper, beginner electronics, and maker projects
Soldered is a strong Seeed Studio alternative if your project involves e-paper displays, beginner electronics, Arduino-compatible learning, ESP32 boards or Raspberry Pi hardware.
The difference is focus. Seeed Studio covers a very broad ecosystem. Soldered concentrates on project-friendly boards, solder kits and Inkplate e-paper displays. That suits builders who want a dashboard, a smart home status board, a weather station, a calendar or a classroom project without assembling the platform from raw components first.
Best for: e-paper dashboards, Inkplate projects, solder kits, Arduino-compatible learning, ESP32 and RP2350 boards, Raspberry Pi products, sensors and Qwiic modules.
Limitation: the catalog is smaller than Seeed Studio's, and there is no industrial edge AI line.
The Inkplate displays are the clearest example of the all-in-one approach. Each one is an e-paper panel with an ESP32, battery management and a library already written for it. Inkplate 10 is the 9.7-inch model most dashboards end up using.
On the microcontroller side, NULA Mini covers Wi-Fi 6 and Thread in a board the size of a stamp, and the Zero to Hero kit covers learning electronics from nothing.
2. Adafruit: best for beginner tutorials and learning resources
Adafruit's real product is its documentation. The Learn guides, the CircuitPython ecosystem, the Feather board family and a deep sensor range make it the easiest place to start if you learn by following a written tutorial.
Best for: learning electronics, CircuitPython, sensors, wearables, small displays, classroom projects.
Limitation: prices are higher than most of this list, availability varies by region, and there is no all-in-one e-paper dashboard platform.
3. SparkFun: best for sensors, breakout boards, and educational electronics
SparkFun makes breakout boards well. The Qwiic connector system lets you chain I2C modules with one cable, and the robotics and education kits are used in a lot of classrooms.
Best for: sensor prototyping, Qwiic modules, robotics, teaching electronics, breakout boards.
Limitation: like Seeed Studio, the catalog is broad enough that you still have to plan the project yourself. Complete e-paper display platforms are not part of the range.
4. Arduino: best for official boards and learning the Arduino ecosystem
Arduino is not a replacement for a component store, but it is the right answer if you mainly want official boards and the learning material built around them.
Best for: a first microcontroller project, official Arduino boards, classroom electronics, simple sensors and actuators.
Limitation: narrow as a general marketplace. If you need several display sizes, e-paper boards, Raspberry Pi accessories or industrial hardware, you will be shopping elsewhere too. Our guide to Arduino alternatives covers that in more detail.
5. Pimoroni: best for Raspberry Pi accessories and creative maker hardware
Pimoroni designs Raspberry Pi and Pico add-ons with more personality than most. Displays, environmental sensors, robotics kits and a lot of small boards that each do one thing nicely.
Best for: Raspberry Pi accessories, Pico projects, small displays, sensors, creative kits, home lab electronics.
Limitation: stronger in Pi and Pico accessories than in complete e-paper platforms, and no industrial IoT range.
6. Waveshare: best for raw display modules and low-cost variety
Waveshare overlaps with Seeed Studio more than anything else here: modules, displays, Raspberry Pi HATs, communication boards. Prices are low and the range of e-paper panels is large.
Best for: raw displays, Raspberry Pi HATs, e-paper panels, communication modules, budget hardware.
Limitation: you do the integration. Documentation quality varies by product, and a raw panel needs wiring, a driver board, power management and library work before it shows anything. We compare that trade-off directly in our Waveshare alternatives guide.
Seeed Studio alternatives compared
| Alternative | Best for | Main strength | Limitation |
| Soldered | E-paper dashboards, beginner electronics, solder kits, ESP32 and Raspberry Pi projects | Focused range built around Inkplate displays and project-ready boards | Smaller catalog than Seeed Studio |
| Adafruit | Beginner tutorials, CircuitPython, sensors, small boards | Best written learning material in the industry | Higher prices |
| SparkFun | Sensors, Qwiic modules, robotics, breakout boards | Strong sensor and education ecosystem | Broad catalog still needs project planning |
| Arduino | Official beginner boards and the Arduino ecosystem | Simplest possible starting point | Not a general hardware marketplace |
| Pimoroni | Raspberry Pi accessories and creative projects | Well-designed Pi and Pico add-ons | No industrial IoT range |
| Waveshare | Raw displays, HATs, low-cost modules | Large hardware variety at low prices | Much more setup and integration work |
Soldered vs Seeed Studio
| Category | Seeed Studio | Soldered |
| Catalog size | Very broad | More focused |
| Strongest areas | Grove, XIAO, edge AI, sensors, industrial IoT | Inkplate e-paper, beginner kits, NULA boards, maker displays |
| E-paper approach | Panels and display modules | Inkplate, an all-in-one platform with ESP32 and battery management |
| Module connector | Grove, a proprietary 4-pin system | Qwiic, the standard 4-pin I2C connector |
| Beginner learning | Grove kits, tutorials, modules | Solder kits and project-based electronics courses |
| Smart home dashboards | Possible by combining components | What Inkplate was designed for |
| Raspberry Pi | Boards, accessories, edge AI systems | Boards, AI Camera, AI HAT |
| Manufacturing | Shenzhen, China | Osijek, Croatia |
Neither one is better in general. Seeed Studio is a broad ecosystem that reaches from Grove sensors to edge AI and industrial systems. Soldered is narrower and aimed at e-paper dashboards, beginner kits, Arduino-compatible and ESP32 boards, and Raspberry Pi maker projects.
Best alternative by project type
| Project type | Best choice | Why |
| E-paper dashboard | Soldered | Inkplate ships as a working platform, not a panel |
| Smart home status board | Soldered | Inkplate 10 and 6FLICK suit always-visible displays |
| Beginner soldering project | Soldered | Solder kits end in a device that does something |
| Grove-based quick prototype | Seeed Studio | Grove is Seeed Studio's biggest strength |
| Tiny development board | Seeed Studio or Soldered | XIAO and NULA cover different compact-board needs |
| Raspberry Pi AI project | Seeed Studio or Soldered | Both stock Raspberry Pi and AI accelerators |
| Raw e-paper module | Waveshare | Cheapest route if you want to do the integration |
| Beginner coding tutorial | Adafruit or Arduino | Best step-by-step learning content |
Where Soldered is strongest compared with Seeed Studio
E-paper dashboards and Inkplate displays
Building an e-paper project from parts means sourcing a panel, a driver board, a microcontroller, power management and an enclosure, then handling the waveforms yourself. Inkplate does that work in advance. You get a panel with an ESP32, battery charging, a Qwiic connector and a library with working examples.
The lineup covers most of what people build: black and white for text-heavy dashboards, colour for signage and art, touch for interactive panels, fast refresh for anything that updates often, and 13 inches for a wall display.
Typical uses are calendars, weather dashboards, smart home status boards, energy monitors, shelf labels, signage and classroom displays. Our roundup of e-paper display projects goes through fifteen of them, and there is a separate guide to e-paper displays for Home Assistant dashboards if that is your setup.
Beginner electronics and solder kits
A bag of components teaches you less than a kit that turns into a game. Each Soldered solder kit is a small finished device: a piano you play with touch keys, an LED dice, a reaction timer, a Simon Says clone, a Pomodoro timer. You learn to solder, read a circuit and debug it, and you keep the result.
The make-your-own kits go further and have you assemble a working Arduino-compatible board from bare parts, either a Dasduino or a NULA. If you would rather compare the options first, our guide to the best soldering kits for beginners covers what to look for.
ESP32, RP2350, and NULA boards
NULA is the compact board family, and each one is built for a specific job rather than being a general-purpose module.
- NULA Mini ESP32-C6 for connected projects. Wi-Fi 6, Bluetooth 5 and Thread, so it talks to Matter networks.
- NULA Max RP2350 for heavier microcontroller work, including DVI video output.
- NULA DeepSleep ESP32-S3 for battery projects. 7 µA in deep sleep.
- NULA Ethernet W55RP20 for wired networking without a separate Ethernet module.
- NULA Core for classic ATmega328 Arduino work.
If you are still deciding which class of board a project needs, Arduino vs Raspberry Pi vs ESP32 lays out the trade-offs.
Raspberry Pi and AI projects
Soldered is an authorised Raspberry Pi reseller, so the Pi 5 and the AI accessories sit in the same catalog as the displays and boards you will pair them with. A Pi 5 handles dashboards, home servers, local automation and coding, in 4 GB, 8 GB and 16 GB versions. The AI Camera runs inference on the sensor itself, and the AI HAT adds 13 or 26 TOPS for object detection and vision work.
Why Soldered is a strong Seeed Studio alternative for maker projects
Seeed Studio is the right choice when you want access to a very broad hardware ecosystem. If your project is more specific, and especially if it involves e-paper displays, beginner electronics, Arduino-compatible learning, ESP32 boards or Raspberry Pi, Soldered is usually the faster starting point.
Inkplate is the clearest case. For an e-paper calendar, a weather dashboard, a smart home status board or a workshop display, an Inkplate gets you further on day one than a raw panel does. The NULA boards, Raspberry Pi products and solder kits then cover the path from a first soldered joint to a finished build.
Frequently asked questions
What is the best Seeed Studio alternative?
It depends on what you are building. Soldered is a strong choice for e-paper dashboards, beginner electronics, solder kits, ESP32 projects and Raspberry Pi builds. Adafruit, SparkFun, Arduino, Pimoroni and Waveshare each cover different ground.
Is Soldered a good Seeed Studio alternative?
Yes, if you want a focused range rather than a marketplace. Soldered is strongest in Inkplate e-paper displays, beginner electronics kits, soldering projects, ESP32 boards, Raspberry Pi products and smart home dashboard projects.
What is the difference between Seeed Studio and Soldered?
Seeed Studio has a very broad catalog covering Grove modules, XIAO boards, sensors, edge AI hardware, robotics and industrial systems. Soldered is narrower and built around maker-friendly boards, Inkplate e-paper displays, solder kits, Raspberry Pi products and beginner electronics. Soldered also manufactures in the EU, in Osijek, Croatia.
What is the best Seeed Studio alternative for e-paper displays?
Soldered, because of Inkplate. Each Inkplate is a complete e-paper platform with an ESP32, battery management and a maintained library, which suits dashboards, calendars, smart home status boards, energy monitors and classroom displays. If e-paper is new to you, start with what an e-paper display actually is.
What is the best alternative to Seeed Grove?
Qwiic. Both SparkFun and Soldered use it, and unlike Grove it is a standard 4-pin I2C connector rather than a proprietary one, so modules from different manufacturers chain together on the same bus.
Is Seeed Studio better than Adafruit?
They are strong in different places. Seeed Studio is known for Grove, XIAO, sensors, industrial IoT and edge AI. Adafruit is known for beginner tutorials, CircuitPython and educational electronics.
Is Seeed Studio better than Waveshare?
Seeed Studio is usually stronger for Grove prototyping, XIAO boards and documentation. Waveshare is cheaper and has more raw display modules and Raspberry Pi HATs. Pick based on whether you want an ecosystem or a specific part.
Which Seeed Studio alternative is best for beginners?
Soldered, Adafruit, Arduino and SparkFun are all reasonable. Soldered is the most hands-on of the four thanks to the solder kits and project-based electronics courses.
