17.07.2026
Raspberry Pi AI Camera: How it works, specifications, and project ideas
What is the Raspberry Pi AI Camera?
Most cameras simply capture images.
An AI camera goes a step further by understanding what's happening inside those images. Instead of sending every frame to a computer for processing, it can identify objects, recognize patterns, and perform AI tasks directly on the device.
The Raspberry Pi AI Camera makes this technology accessible to makers, students, and developers. Whether you're building a wildlife monitor, smart security system, or object detection project, it provides a simple way to bring computer vision and artificial intelligence to Raspberry Pi.
In this guide, we'll explain how the Raspberry Pi AI Camera works, what makes it different from a standard camera module, and some of the most interesting projects you can build with it.
The Raspberry Pi AI Camera is a camera module that combines image capture and artificial intelligence in a single device. Unlike traditional camera modules that simply capture photos or video, the AI Camera can analyze what it sees in real time using built-in AI processing.
At the heart of the camera is the Sony IMX500 image sensor, which includes dedicated AI hardware directly on the sensor itself. This allows machine learning models to run on the camera rather than relying entirely on the Raspberry Pi's CPU.
The result is a camera that can identify objects, classify images, estimate human poses, and perform other computer vision tasks while using fewer system resources and responding more quickly.
Raspberry Pi AI-Kamera
€99,95
€99,95
What makes an AI camera different from a regular camera?
At first glance, an AI camera may look identical to a standard camera module. The difference lies in what happens after an image is captured.
A traditional camera records image data and sends it to a computer for processing. If you want to detect people, recognize objects, or analyze a scene, the Raspberry Pi must perform those calculations itself or send the data to a cloud service.
An AI camera takes a different approach. It can process images directly on the device and return useful information such as object locations, classifications, or detection results. This reduces processing overhead, improves response times, and can make AI applications more efficient.
Standard camera
AI camera
Captures images
Captures and analyzes images
Requires processing elsewhere
Performs AI inference on-device
Sends full image data for analysis
Can send detection results directly
Places more workload on the host system
Reduces processing requirements
Primarily designed for imaging
Designed for imaging and computer vision
For makers, this means it's easier to build projects such as smart security cameras, wildlife monitoring systems, package detectors, and AI-powered automation devices without requiring powerful hardware or cloud-based processing.
Raspberry Pi AI Camera specifications
While the Raspberry Pi AI Camera is designed to be easy to use, it packs some impressive hardware under the hood. The combination of a high-resolution image sensor and built-in AI acceleration allows it to perform computer vision tasks directly on the camera without placing the entire workload on the Raspberry Pi itself.
Feature
Specification
Image sensor
Sony IMX500
Resolution
12.3 MP
AI processing
Integrated on-sensor AI acceleration
Lens
Built-in fixed-focus lens
Connectivity
MIPI CSI camera interface
Computer vision support
Object detection, image classification, pose estimation
Compatible boards
Raspberry Pi 5, Raspberry Pi 4, Raspberry Pi Zero 2 W and other Raspberry Pi boards with camera support
AI inference location
Directly on the camera sensor
Software support
Raspberry Pi OS and Raspberry Pi AI software stack
The standout feature is the Sony IMX500 sensor, which combines image capture and AI processing in a single component.
Raspberry Pi AI Camera projects you can build
One of the biggest advantages of the Raspberry Pi AI Camera is that it makes computer vision far more accessible. Tasks that previously required powerful hardware or cloud-based processing can now run directly on the camera, opening the door to a wide range of practical projects.
AI-powered security camera
Traditional security cameras record everything they see. An AI-powered security camera can go a step further by detecting people, vehicles, or other specific objects and only sending alerts when something important happens. This reduces false alarms and makes monitoring more effective.
Raspberry Pi AI HAT+
Normaler Preis  €99,95 Angebotspreis  €69,95
Wildlife monitoring camera
Whether you're interested in birdwatching or observing local wildlife, an AI camera can automatically detect and capture animals as they appear. Instead of sorting through hours of footage, you can focus only on the moments that matter.
Smart recycling assistant
Recycling can be confusing, especially when different materials look similar. By using image classification, a Raspberry Pi AI Camera can identify common objects and help determine whether they belong in recycling, compost, or general waste.
Package delivery detector
Waiting for an important delivery? An AI-powered package detector can monitor your doorstep and send a notification when a parcel is placed in a designated area. Unlike simple motion sensors, computer vision allows the system to recognize packages rather than reacting to every movement.
Occupancy monitoring system
Occupancy monitoring can be useful in offices, meeting rooms, classrooms, and public spaces. An AI camera can estimate how many people are present in a room and provide real-time occupancy information without requiring manual tracking.
Whether you're interested in automation, smart homes, wildlife observation, or artificial intelligence, these projects demonstrate how accessible computer vision has become. With built-in AI acceleration and support for machine learning models, the Raspberry Pi AI Camera provides a practical starting point for experimenting with real-world AI applications.
€99,95
€99,95
Why Soldered is a great place to start building AI projects
Artificial intelligence is no longer limited to data centers, cloud platforms, or expensive hardware. With tools like the Raspberry Pi AI Camera, makers, students, and developers can now experiment with computer vision and edge AI from their own workbench.
Whether you're building a wildlife monitoring station, a smart security camera, or an object detection system, the Raspberry Pi ecosystem makes it easier than ever to turn AI ideas into real-world projects. The combination of accessible hardware, active communities, and growing software support means there's never been a better time to start exploring what AI can do.
At Soldered, you'll find Raspberry Pi boards, AI accessories, sensors, and displays that help bring these projects to life. From the Raspberry Pi AI Camera for computer vision applications to the Raspberry Pi AI HAT for more demanding AI workloads, we provide the hardware and resources needed to help makers move from experimentation to deployment.
The most exciting part isn't the technology itself. It's what you choose to build with it. Whether you're taking your first steps into computer vision or creating advanced edge AI applications, the Raspberry Pi AI Camera is a powerful platform for learning, prototyping, and innovation.
Raspberry Pi AI camera: FAQs
The Raspberry Pi AI Camera is a camera module that combines image capture and artificial intelligence in a single device. Built around the Sony IMX500 image sensor, it can perform AI tasks such as object detection, image classification, and pose estimation directly on the camera.
How does the Raspberry Pi AI Camera work?
The Raspberry Pi AI Camera uses the Sony IMX500 vision sensor, which includes dedicated AI processing hardware. Instead of sending every image to the Raspberry Pi for analysis, the camera can run machine learning models on-device and return useful information such as detected objects or classifications.
What is the Sony IMX500 sensor?
The Sony IMX500 is an intelligent vision sensor that combines a 12.3 MP image sensor with integrated AI processing capabilities. It enables computer vision tasks to run directly on the sensor, reducing latency and lowering the processing requirements of the host device.
Does the Raspberry Pi AI Camera require an internet connection?
No. One of the main advantages of the Raspberry Pi AI Camera is that AI inference can run locally on the device. Many computer vision tasks can be performed without sending data to the cloud, improving privacy and reducing latency.
What Raspberry Pi boards are compatible with the AI Camera?
The Raspberry Pi AI Camera is compatible with Raspberry Pi boards that support camera modules through the CSI interface, including Raspberry Pi 5, Raspberry Pi 4, and Raspberry Pi Zero 2 W.
What is the difference between the Raspberry Pi AI Camera and Camera Module 3?
The Raspberry Pi AI Camera includes built-in AI processing capabilities through the Sony IMX500 sensor, allowing it to perform computer vision tasks directly on the camera. Camera Module 3 focuses on image and video capture and relies on the Raspberry Pi itself for any AI or computer vision processing.
Do I need a Raspberry Pi AI HAT if I have the AI Camera?
Not necessarily. The Raspberry Pi AI Camera can perform many computer vision tasks on its own. However, the Raspberry Pi AI HAT can provide additional AI acceleration for more demanding machine learning workloads, larger models, or advanced edge AI projects.
Verwandte Artikel
