30.06.2026
What is ESPHome? A beginner's guide to building smart home devices
That's where ESPHome comes in.
ESPHome makes it easy to turn ESP32 and ESP8266 boards into smart home devices without needing extensive programming experience. With a simple configuration file, you can create temperature sensors, energy monitors, weather stations, smart switches, and countless other devices that integrate directly with Home Assistant.
What is ESPHome?
What is ESPHome?
We're all pretty aware that smart homes are no longer reserved for expensive hubs and closed ecosystems.
Today, pretty much anyone can build custom sensors, monitor their home in real time, and automate everyday tasks using affordable hardware and open-source software.
So, what's the biggest challenge? Traditional microcontroller projects often require writing firmware, configuring communication protocols, and spending hours troubleshooting code before anything actually works.
What is ESPHome?
ESPHome is an open-source platform that allows you to create smart home devices using ESP32 and ESP8266 microcontrollers. Instead of writing firmware from scratch, you define how your device should work using a simple YAML configuration file, and ESPHome generates the code for you.
This approach makes it possible to build custom sensors, displays, switches, relays, and monitoring devices without needing deep embedded programming knowledge.
A simple way to build smart home devices
At its core, ESPHome removes much of the complexity traditionally associated with microcontroller development.
Let's say you want to create a temperature sensor for Home Assistant. Normally, you'd need to write firmware, configure communication protocols, handle Wi-Fi connectivity, and ensure everything works reliably together.
With ESPHome, most of that work is handled for you. You simply define your hardware, configure a few settings, and upload the generated firmware to your device.
This allows makers to focus on what they're building rather than spending hours writing and debugging code.
How ESPHome works
ESPHome follows a straightforward workflow:
  1. Connect an ESP32 or ESP8266 board.
  2. Create a YAML configuration file.
  3. Define sensors, displays, switches, or other components.
  4. Generate and upload the firmware.
  5. Connect the device to Home Assistant.
Once deployed, the device can automatically send data, receive commands, and participate in automations across your smart home.
One of the biggest advantages is that updates can be delivered wirelessly using OTA (Over-The-Air) updates, meaning you often won't need to reconnect the device to your computer after the initial setup.
Why Home Assistant users love ESPHome
ESPHome and Home Assistant are designed to work together.
Devices are automatically discovered, entities appear inside Home Assistant with minimal configuration, and sensor data can immediately be used in dashboards and automations.
Some common ESPHome projects include:
  • Temperature and humidity sensors
  • Energy monitoring devices
  • Smart lighting controllers
  • Air quality monitors
  • Weather stations
  • Smart home dashboards
This tight integration is one of the main reasons ESPHome has become a favorite among Home Assistant users.
What hardware can you use with ESPHome?
One of the biggest reasons for ESPHome's popularity is its hardware flexibility. Whether you're building a simple temperature sensor or a fully featured smart home dashboard, ESPHome supports a wide range of boards, sensors, displays, and accessories.
That means you can start with a basic project and gradually expand it as your skills and requirements grow.
ESP32 boards
ESP32 boards are the most popular hardware platform for ESPHome projects. They offer built-in Wi-Fi and Bluetooth connectivity, plenty of processing power, and support for a huge range of sensors and peripherals.
For most new projects, an ESP32 board is the recommended starting point because it provides more features and flexibility than older microcontroller platforms.
One option worth considering is the NULA Mini ESP32-C6, which combines Wi-Fi 6, Bluetooth 5, and Matter support in a compact form factor. This makes it a strong choice for modern smart home devices, Home Assistant integrations, environmental monitoring systems, and connected IoT projects.
ESP8266 boards
Before the ESP32 became the go-to choice for makers, many ESPHome projects were built using ESP8266 boards.
They're still widely supported and remain a cost-effective option for simple projects such as:
  • Temperature sensors
  • Smart plugs
  • Basic relays
  • Light controllers
  • Presence sensors
While they offer less processing power and fewer features than ESP32 boards, they can still be a practical solution for straightforward automations.
Sensors
Sensors are where ESPHome really shines. The platform supports hundreds of sensor types, allowing you to collect data from your environment and use it throughout Home Assistant.
Popular examples include:
  • Humidity sensors
  • Air quality sensors
  • Motion sensors
  • Light sensors
  • Current and voltage sensors
  • Distance sensors
These devices can power everything from weather stations and greenhouse monitors to energy dashboards and occupancy tracking systems.
Displays
ESPHome isn't limited to collecting data. It can also display information using a variety of screens and dashboard solutions.
Many makers use displays to show:
  • Weather information
  • Room temperatures
  • Energy usage
  • Device status
  • Smart home alerts
  • Calendar events
This is one reason ESPHome pairs so well with display platforms such as Inkplate, allowing users to build always-on dashboards that integrate directly with Home Assistant.
Relays and actuators
Smart homes don't just monitor information, they act on it.
ESPHome supports a wide range of relays and actuators that allow devices to control the physical world around them.
Common examples include:
  • Lighting control
  • Smart switches
  • Garage door controllers
  • Irrigation systems
  • Fans and ventilation
  • Motorized devices
  • Home automation triggers
By combining sensors, displays, and relays, makers can build complete smart home solutions that both monitor conditions and respond automatically to changing events.
Popular ESPHome projects makers build
One of the best things about ESPHome is that it turns everyday ideas into weekend projects.
What starts as a simple temperature sensor often turns into a smart home dashboard, an energy monitor, a weather station, and eventually a house filled with automations you built yourself. Because ESPHome works so well with Home Assistant, it's become one of the most popular platforms for makers who enjoy creating practical devices that solve real problems.
Here are some of the projects makers build most often.
Almost every ESPHome journey starts here.
A small ESP32 board and a sensor can give you real-time temperature and humidity readings for any room in your home. People use them to monitor nurseries, greenhouses, wine cellars, server racks, garages, and just about any space where environmental conditions matter.
The best part? Once the data reaches Home Assistant, you can build automations around it. Too hot? Turn on a fan. Too humid? Start a dehumidifier. Too cold? Trigger a notification before your plants freeze.
Ever wondered why your electricity bill suddenly jumped?
Energy monitoring projects help answer that question.
Using ESPHome, makers build devices that track power consumption throughout the day and identify which appliances are using the most energy. Many users become slightly obsessed after seeing their first energy dashboard, discovering that an old fridge, gaming PC, or forgotten appliance is quietly consuming power around the clock.
Smart plant monitors
For people who love plants but occasionally forget they exist, ESPHome can help.
A smart plant monitor can track soil moisture, temperature, humidity, and light levels, then send updates directly to Home Assistant. Instead of guessing when a plant needs water, you'll know exactly when it's time.
Some makers even create automated watering systems that handle the job for them.
Lighting projects are where things start getting fun.
ESPHome can control LED strips, desk lighting, ambient room lighting, and decorative installations. Want your office lights to turn blue when it rains? Your shelves to glow red when a server goes offline? Your living room to switch to movie mode automatically?
This is the kind of project ESPHome excels at.
Garage door sensors
Few things are more annoying than driving away and wondering:
"Did I close the garage door?"
ESPHome makes it easy to build a sensor that reports the status of your garage door directly to Home Assistant. Many makers take it a step further by adding remote control capabilities, allowing them to open or close the door from anywhere.
Weather stations
Weather stations are a favorite project because they're both useful and surprisingly addictive.
With a handful of sensors, you can monitor local temperature, humidity, air pressure, rainfall, and wind conditions in real time. Instead of relying solely on a weather app, you're collecting data from your own backyard.
For many makers, this becomes their first "serious" ESPHome build.
ESPHome dashboards and displays
ESPHome isn't just about collecting data. It's about putting that data where you can actually see it.
Instead of opening Home Assistant dozens of times a day, many makers build dedicated displays that show weather updates, energy usage, calendar events, smart home alerts, and device status at a glance.
Popular ESPHome display projects include:
  • Home Assistant dashboards
  • Energy monitoring screens
  • Family information boards
  • Weather stations
  • Smart home control panels
  • Device status displays
Why e-paper works so well with ESPHome
Most dashboard information doesn't change every second. That's why e-paper displays are such a natural fit for ESPHome projects.
Unlike traditional LCD screens, e-paper remains visible without constantly consuming power, is easy to read in bright environments, and blends naturally into a home or office setup.
Building ESPHome dashboards with Inkplate
The Inkplate 10 is ideal for larger Home Assistant dashboards, weather stations, family calendars, and energy monitoring displays where readability is the priority. Its large screen provides plenty of space for displaying multiple widgets and data sources at once.
For projects that require more frequent updates, the Inkplate 6FLICK combines e-paper readability with fast refresh technology, making it well suited for smart home status panels, IoT dashboards, and interactive information displays.
Whether you're building a simple weather dashboard or a dedicated Home Assistant control center, Inkplate displays make it easy to bring your ESPHome data out of the app and into the real world.
€189,95
€189,95 - €219,95
Inkplate 6FLICK
Inkplate 6FLICK
€179,95
€179,95 - €209,95
ESPHome vs. Arduino and MQTT: What's the difference?
If you're researching ESPHome, you've probably also come across Arduino and MQTT. While all three are commonly used in IoT and smart home projects, they solve different problems. Understanding where each one fits can help you choose the right tool for your project.
ESPHome vs Arduino
Feature ESPHome Arduino
Ease of setup Beginner-friendly More technical
Coding required Minimal Extensive
Home Assistant integration Native Requires additional development
Flexibility Focused on smart home projects Suitable for almost any embedded project
Learning curve Low Moderate to high
ESPHome is designed to simplify smart home development. Instead of writing firmware from scratch, users define devices using simple configuration files and let ESPHome generate the code automatically.
Arduino offers significantly more flexibility and control but requires programming knowledge. It's often the better choice for custom hardware projects, robotics, and applications that extend beyond the smart home ecosystem.
For most Home Assistant users, ESPHome provides a faster path from idea to working device.
Why Soldered boards work well with ESPHome
One of the reasons ESPHome has become so popular is that it lowers the barrier to building connected devices. The same philosophy applies to Soldered hardware.
Whether you're creating a simple temperature sensor, a Home Assistant dashboard, or a complete smart home automation system, Soldered's ecosystem is designed to help you spend less time wiring and troubleshooting and more time building.
At the heart of many ESPHome projects is the NULA Mini ESP32-C6, a compact development board that combines Wi-Fi 6, Bluetooth 5, and Matter support with full ESP32 compatibility. This makes it an excellent foundation for everything from environmental monitoring and energy tracking to advanced smart home devices.
The experience becomes even simpler when paired with Soldered's easyC ecosystem. Instead of dealing with complex wiring, makers can connect compatible sensors and modules using plug-and-play cables, making it easy to expand projects as new ideas emerge.
This combination works particularly well for:
  • Home Assistant devices
  • ESPHome sensors and monitoring systems
  • Smart home automations
  • Weather stations
  • Energy monitoring projects
  • E-paper dashboards and status displays
ESPHome: FAQs
What is ESPHome?
ESPHome is an open-source platform that allows you to create smart home devices using ESP32 and ESP8266 microcontrollers. Instead of writing firmware from scratch, users define their devices through simple configuration files and integrate them directly with Home Assistant.
Is ESPHome free?
Yes. ESPHome is completely free and open source. You can download, modify, and use it without licensing fees, making it a popular choice for DIY smart home and IoT projects.
What boards work with ESPHome?
ESPHome supports a wide range of ESP32 and ESP8266 development boards. Popular options include the NULA Mini ESP32-C6, ESP32 DevKit boards, ESP32-S3 boards, and ESP8266-based devices such as the NodeMCU.
Does ESPHome require coding?
Not usually. Most projects can be created using YAML configuration files rather than traditional programming. While advanced users can customize their projects further, beginners can build functional devices with little to no coding experience.
Can ESPHome work without Home Assistant?
Yes. Although ESPHome is most commonly used with Home Assistant, it can also communicate through MQTT and operate independently for many applications. However, Home Assistant provides the most seamless integration and management experience.
What is the difference between ESPHome and Arduino?
ESPHome focuses on simplifying smart home development through configuration-based device creation and native Home Assistant integration. Arduino provides greater flexibility and control but typically requires writing and maintaining code for each project.
What is the difference between ESPHome and MQTT?
ESPHome is a platform for building and managing devices, while MQTT is a messaging protocol used to exchange data between devices and applications. Many ESPHome projects can use MQTT as a communication method.
What are the best ESPHome projects?
Some of the most popular ESPHome projects include temperature and humidity sensors, weather stations, air quality monitors, energy monitoring systems, smart lighting controllers, garage door sensors, and Home Assistant dashboards.
[product="
Verwandte Artikel
