The accuracy of the voltmeter can easily be calculated by dividing 5V / 1023, which gives us a step of 4,88mV. Depending on the resistors that you use, there will be a deviation of the actual and the read voltage. If you have the option, compare the voltmeter with the laboratory one.
ARDUINO / DASDUINO VOLTMETER PROJECT
This voltmeter project is a continuation of a tutorial on INPUT / OUTPUT pins.
WARNING: Be careful when testing voltage. Atmega328 bears a maximum voltage of 5V, if you want to measure higher voltages skip to the part of the resistant divider (voltage divider).
CONNECTING
We need two cables: GND (-) and (+). GND connects to GND, and (+) to measure the analog pin 0 Dasduino. By no means, do not connect voltage greater than 5V to Dasduino!
CODE
If you don’t understand the code, we suggest that you look at the tutorial on the input / output pins.
VOLTAGE DIVIDER
Voltage divider or resistance divider is a series of two resistors which descend voltage. Resistor closer to the input voltage (Vin) is denoted as R1, and resistor closer to gnd is denoted as R2. The voltage drop across R2 is Vout, and marks the divided voltage of our circuit. In the example above, we use R1 = 10K and R2 = 1kΩ. It is calculated according to the formula:
That is, if the value of the input voltage (Vin) is equal to 40V, output (Vout) will be at Vout = 40 * (1 / (10 + 1)) = 3.636V. This is the voltage that the microcontroller can handle. The maximum input voltage for this combination of resistor is 55V, but for safety, let’s call it 0-40VDC voltmeter.
This formula will be included in the Arduino code, and it is up to us to be careful not to cross the maximum allowable input voltage.
int r1= 10; // r1 is 10k ohmsint r2 = 1; // r2 is 1k ohmint input = A0; // voltage is measured via analog pins A0void setup() { pinMode(input, INPUT); Serial.begin(9600); // starting serial communication}void loop() { // summon the function that returns the corrected input voltage float inputVoltage = VoltageDivider(input); // printing voltage Serial.print("Input voltage = "); Serial.println(inputVoltage);}void VoltageDivider(int pin) { int vout_a = analogRead(pin); // The first step is to read the analog value of Vout voltage divided with voltage divider float vout_v = map(vin_a, 0, 1023, 0, 5); // mapping the printed value in voltage float vin = vout_v * ( (r1+r2) / r2 ); // Since we know the value of the resistor, the voltage at pin A0 is converted to the actual voltage // Vin, before voltage divider return vin; // return restated value}
