HUM: VIBRATION SENSOR MODULE
HUM: VIBRATION SENSOR MODULE-Uncategorized
BASIC CHARACTERISTICS
Vibration sensor module is a breakout module for the SW-420 vibration sensor with the LM393 comparator. Except for vibration detectors, we find it in anti-theft devices.
Characteristics:
Model: SW-420
Voltage: 3.3V-5V
Electricity: >15mA
Dimensions: 3.8 x 1.3 x 0.7 cm
Weight: 5g
WORK PRINCIPLE
The main part of the module is a vibration sensor SW-420. These sensors usually have a little ball inside. When it moves, the “impacts” are detected on the edges and in all directions thanks to the roller shaped housing. The module itself has two signaling LEDs: the red one is a power LED, and the green one is activated while detecting vibrations or titrations. When there is no detected vibration the output module logic is LOW and vice versa.
On the module, there is also LM393 analog voltage comparator which functions as a small voltmeter with integrated switches. It measures voltage in two different points and compares the difference. If the voltage in the first point is higher than that of the second one, the switch is on. In reverse, the switch is off. The comparison voltage is adjusted using built-in potentiometer on the module, using which we decide when the module will send LOW signal via digital output pin. This allows us to use module even without logic controllers.
HOW TO CONNECT MODULE WITH DASDUINO
Vcc – 3.3V ili 5V
gnd – gnd
D0 – digital pin 2
MODULE CODE
The principle is very uncomplicated. The module sends HIGH signal via D0 pin onto Dasduino when it reads off a vibration or impulse (given the sensibility we have set on the potentiometer). To apply this we can use the code that comes with Arduino IDE  DigitalReadSerial”, and find it in:
File – Examples – Basic – DigitalReadSerial
Each 1ms, it reads the status of the digital pin 2 and prints the value (0 for LOW, 1 for HIGH)  in SerialMonitor.
