HUM: SOUND DETECTOR MODULE
BASIC CHARACTERISTICS
The sound detector module is the module which sends a signal through a digital output when it detects a sound. While detecting, it sends a LOW signal and illuminates the signal LED diode embedded on the module. It can be used for acustic light control and similar sound control or simply as a sound detector.
Characteristics:
Voltage: 4V-6V
Dimensions: 3.8 x 1.6 x 1.0 cm
Weight: 4g
WORK PRINCIPLE
The basic part of the module is a small condensing microphone which turns the sound energy into electric energy. These microphones consist of a membrane (made of electret material) and solid panel. The titration of the membrane changes the gap between the electrodes, which affects the change of the capacity or the electrical voltage. When there are no detected sounds the output module logic is HIGH and vice versa. The module has a built-in signaling LED that illuminates when the module detects a sound.
On the module, there is also LM393 analog voltage comparator which functions as a small voltmeter with integrated switches. It measures voltage in two different points and compares the difference. If the voltage in the first point is higher than that of the second one, the switch is on. In reverse, the switch is off. The comparison voltage is adjusted using built-in potentiometer on the module, using which we decide when the module will send LOW signal via digital output pin. This allows us to use module even without logic controllers.
HOW TO CONNECT MODULE WITH DASDUINO
Vcc – 5V
gnd – gnd
out – digital pin 2
MODULE CODE
The principle is very uncomplicated. The module sends LOW signal via the digital OUT pin onto the Dasduino, which detects vibration or impulse (given the sensibility we have set on the potentiometer). To apply this we can use the code that comes with Arduino IDE “DigitalReadSerial”, and find it in:
File – Examples – Basic – DigitalReadSerial
Each 1ms, it reads the status of the digital pin 2 and prints the value (0 for LOW, 1 for HIGH) in SerialMonitor.
